Wiring help for volt meter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 11-06-2012, 12:15 PM Thread Starter
87 VN750 Lookin Good
acisroc's Avatar
Send a message via Skype™ to acisroc
Question Wiring help for volt meter
Hey guys After installing a small windshield on my bike and having the engine rebuilt and shifter inside the motor rewelded, I thought what a great place for a voltmeter to mount without drilling any holes. I bent an old bracket to fit on the windshield mounting bolts, mounted the volt meter to the windshield and ran the wires to the inside of headlight: Now where is the best place to wire up the meter, and guage light? and what guage and color are the wires? Looks great,above and between the tach and speedo. Just need to wire it up so it only comes on in run position.
Thinking I can wire the light to the speedo bulb (color of wire?) but what to tap into for the meter and what color wire? Ive got an 87 vulcan that is really starting to look brand new and runs like a top!
MODS: AGM/MF battery.Rect.Black Mirrors,Smoked windshield H D brakes,Voltmeter,Backrest pack,Chrome brake cover, Chrome res. cover, Hard saddlebags red turn signal lights built in.Custom back rack.Chrome mirror dampeners,Red NGK spark plug wires,K+N air filters, Chrome windshield trim, Chrome fender trim front and rear,Gas tank chrome trim. Extra turn, stop and running led's,ss flame radiator grill, HD stator R/R Mod Low handlebars F+S engine guard, hwy pegs continental II tires,fog lights
acisroc is offline
post #2 of 9 (permalink) Old 11-06-2012, 12:30 PM
there are two wires inside the headlight bucket that go nowhere one is power one is ground you will have to check to see if the power wire is switched or constant i am not sure on this but you can use the ground for sure and you can use the power wire off of the front coil right behind the neck cover if you wanted i know it is switched power
post #3 of 9 (permalink) Old 11-06-2012, 12:56 PM
The power leads in the headlight bucket are a constant hot. Most people have wired the volt meter direct to the battery so as tro get a true reading via a relay which can be triggered by almost any ignition powered lead.
post #4 of 9 (permalink) Old 11-06-2012, 01:05 PM
yup forgot about that but that would be the best way huh?
post #5 of 9 (permalink) Old 11-06-2012, 01:59 PM Thread Starter
acisroc's Avatar
Thanks guys now for a switched ground
I think I will go directly from battery, as suggested (mechanic told me that also today ) Now all I need to do is find a switched ground in the headlight bezel, wich wire color? (no manual yet) Thanks
acisroc is offline
post #6 of 9 (permalink) Old 11-06-2012, 02:18 PM
Arrow
there are no switched grounds !
(except radiator mounted temp. sensor for cooling fan)
WilliamTech
post #7 of 9 (permalink) Old 11-06-2012, 05:52 PM Thread Starter
acisroc's Avatar
Thanks guys
Thanks new rider 9984 there are no switched grounds so your suggestion worked out fine. I jumped the bulb light to the speedo light and the same ground behind the lamp. Now all I need is a crash bar!
acisroc is offline
post #8 of 9 (permalink) Old 11-06-2012, 06:11 PM
You can download the repair manual in my signature. It's not the same as having a clear pictured book I front of you but hey, it's free!
post #9 of 9 (permalink) Old 11-06-2012, 09:30 PM Thread Starter
acisroc's Avatar
Thanks I luck out again
I happen to be looking for books and found the manual at the local thrift stoe $1.00!!!---- Also found a guy last month trading in his 96 750 on a new bike and he swapped seats with me !! looks like new and the dealer got the ripped seat,
acisroc is offline
