no power to the solinoid?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 49 (permalink) Old 10-21-2012, 07:39 PM Thread Starter
knees in the breeze!!!
Tofer76's Avatar
so i go to start the bike today( a beautiful day to ride) and its a no go.
battery is up
everything is lit up as should be
but nothing when i hit the button?
i took the side cover off and jumped the solinoid and it cranks over
so i unplug the 2 wire plug to the solinoid and test it
ground shows continuity
the yellow w/red stripe shows 0.030v when button is pressed, key on
isnt that supposed to be higher???
i checked that wire to the bottom plug in juct. box and it shows continuity
any ideas??
i forgot i took the ends of my batt charger to the spades on the solinoid and it clicks when 12v is applied but nothing on the bike.
as the wire to the one spade is only getting 0.030v when i hit the start button
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #2 of 49 (permalink) Old 10-21-2012, 09:32 PM
yes it should be battery voltage
Is there continuity between ground and Yellow/Green Wire (pin 12 of JB)?
dumb question? Was the bike in Neutral?
post #3 of 49 (permalink) Old 10-21-2012, 09:58 PM Thread Starter
Tofer76's Avatar
I will check the. Cont. Of that wire tomorrow.
Yes bike in neut.
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
post #4 of 49 (permalink) Old 10-22-2012, 04:31 AM
Yes bike in neut.
Make sure bike is still in neutral before checking continuity.
post #5 of 49 (permalink) Old 10-22-2012, 12:13 PM
kill switch???
is it in the "run" position?
post #6 of 49 (permalink) Old 10-22-2012, 12:26 PM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #7 of 49 (permalink) Old 10-22-2012, 05:05 PM Thread Starter
Tofer76's Avatar
yes i have cont to ground at pin 12 (mine is blue)
and yes the kill switch is in the run position otherwise my voltmeter wont work lol
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
post #8 of 49 (permalink) Old 10-22-2012, 06:04 PM
I had to ask....lol
You would be amazed how sometimes the simple things get overlooked.
been there...done that
post #9 of 49 (permalink) Old 10-22-2012, 06:57 PM
Hmm JB headlight mod.. I also think I messed up the troubleshooting chart...but you shouldn't have continuity to ground on pin 12.. it should be 12 volts hot. so, I am going out on a limb and saying you have a bad JB
post #10 of 49 (permalink) Old 10-22-2012, 07:51 PM Thread Starter
Tofer76's Avatar
i havent done the headlight jb mod.
if the jb is bad would everything else work fine???
it does i can get it to start if i jump the solinoid
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
