Starting issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 10-21-2012, 11:29 AM Thread Starter
Starting issue
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #2 of 15 (permalink) Old 10-21-2012, 01:17 PM
Arrow
Originally Posted by FlacoLove View Post
Two days ago I was involved in an accident that resulted in my handlebars facing towards the left, and my front wheel facing slightly to the right, (the trip tree was snapped off at the crown and bent on the bottom); the bike wouldn't start. I replaced the trip-tree, forks, and rebuilt the dash; all the elec's work.
My problem is starting. She starts perfect when I use a screwdriver and make contact to the two solenoid screws (underneath right side-cover), but she wont click when I apply the starter button. Upon disassembly of that starter button, the spring within got lost somewhere within the engine; thus I'm presently working of getting a new/used switch (posted elsewhere).
Can I please get some input as to where my starting problem may lie?
NOTE: the accident happened 4 blocks from home; she wouldn't start (not even click). After being pushed two blocks, I tried starting her again and boom, she started; I rode her two blocks home (twisted as she were); turned her off, but again she won't start unless I use the screwdriver/solenoid method. Ride safe.
I would suspect the handlebar starter button which you are replacing.
Otherwise, clean/check wiring connectors.
When malfunctioning, turning on ignition (lock) switch on, If dash lights do not come on, then it would be in the Ignition switch and/or wiring (connectors).
hope this helps
WilliamTech
post #3 of 15 (permalink) Old 10-21-2012, 01:19 PM
bad electrical connections somewhere... probably the ones on the neck.
post #4 of 15 (permalink) Old 10-21-2012, 01:54 PM
When my son's bike had that problem, I tried starting it while moving the handlebars back and forth. There was a "magic" spot where a connection was made and it would start. That helped me isolate the wires that needed attention. In my case it was the connector between the headlight and the gas tank. You may need to trace all the wires and check them individually from the starter button on.
Green1 is offline
post #5 of 15 (permalink) Old 10-21-2012, 02:00 PM Thread Starter
deleted
post #6 of 15 (permalink) Old 10-21-2012, 02:06 PM
Check the connectors. A wire could have been pulled loose and it may not be visible.
No Brain - No Pain. I measure a man by the good he does for others, not his mistakes.
Green1 is offline
post #7 of 15 (permalink) Old 10-21-2012, 02:37 PM Thread Starter
deleted
post #8 of 15 (permalink) Old 10-21-2012, 02:46 PM
after you jump the solenoid, does the bike stay running?
post #9 of 15 (permalink) Old 10-21-2012, 07:06 PM Thread Starter
deleted
post #10 of 15 (permalink) Old 10-21-2012, 07:19 PM
not the kill switch then.. going to look at some diagrams and get back to you
