unloaded they were getting the same stator reading unloaded.. and if you unplug the tail light and headlight with the R/R plugged in you should be pulling 13.9-14.5 volts through all rpm, ranges, then drop down to 12 with the tail light plugged back in. I racked my brain for 3 months before one fo the guys finally went back and checked stator leg to ground resistance when hot. we came up with .05 ohms with engine at normal operating temps, with engine cold, the same leg to ground was getting a reading of OL. BTW all three stators had less than 2,000 miles, One was a 1 Was a rick's, one was an Electrosport, and the third was a TPE... TPE was the only one that made right as far as I know.
