Ignition Coil - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 10-13-2012, 06:09 PM Thread Starter
originalbat's Avatar
Ignition Coil
As I've stated before my bike starts fine initially. I can let her run for 10 min. or so, then switch her off. After 10 more min. or so she won't fire up. Used tester on battery 11.6v, on solenoid 11.6v, on starter 11.6v. If I use jumper cables or put her back on charge she'll start after a few minutes. A friend who once worked in a bike shop said to check the coils. How do i do that? We were at work and I couldn't quiz him. This beautiful weather we're having in South Louisiana is made for riding. Help please?
originalbat is offline
post #2 of 20 (permalink) Old 10-13-2012, 06:11 PM Thread Starter
I've checked, cleaned and re-checked all grounds. I've also ensured firm connection son all connectors and applied dielectric grease to same
post #3 of 20 (permalink) Old 10-13-2012, 06:29 PM
I doubt its the coils...
I have a few questions.
IF you let the bike sit for several hours after shutting it off, will the bike start again on its own power, or do you have to recharge the battery?
can you jump the bike with a car battery when it won't start?
What is your charging voltage?
What is your battery voltage with every thing off?
What is your Voltage with the key on before you try and start it when you know it won't start?
post #4 of 20 (permalink) Old 10-13-2012, 06:45 PM Thread Starter
I can jump start it with my car. Voltage with everything off, after charging is 12.4. Voltage with key on, before attempt is 11.8 knowing it won't start. As for sitting a few hours, i'm not sure.
post #5 of 20 (permalink) Old 10-13-2012, 07:06 PM
ok so what is the voltage with the bike running after a jump?
post #6 of 20 (permalink) Old 10-13-2012, 07:12 PM Thread Starter
At 5000 rpms, 13.8. At idle, i don't remember. Currently draining fuel tank to remove it to look at wires again
post #7 of 20 (permalink) Old 10-13-2012, 07:20 PM
Arrow
Slim, a $600.00 Stator ?
http://www.ebay.com/itm/Stator-KAWAS...887306&vxp=mtr
WilliamTech
post #8 of 20 (permalink) Old 10-13-2012, 07:53 PM
13.8 is a little week... check it again at idle when the battery needs to be jumped. I am thinking you might have a bad R/R connection or a bad connection at the stator bullets... the coils need 10 volts to fire, but the starter needs 12.5+ to turn the engine over. Also get the battery load tested.
post #9 of 20 (permalink) Old 10-13-2012, 07:54 PM
WilliamTech
Holy cow.. a little ridiculous for a stock replacement.. ya think?
post #10 of 20 (permalink) Old 10-13-2012, 08:36 PM
Chucklehead
dragon159's Avatar
Scary part .... says 49 sold ..... desperate people?
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
