Capacitors installed into R/R for improved reliability - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-29-2006, 04:55 PM Thread Starter
I originally came across this idea based on this link:
http://autos.groups.yahoo.com/group/...ing%20project/
After looking thru the information I had to agree. No different than installing capacitors into the electrical system of a vehicle with oversized amplifiers to help dampen the electrical surges that would otherwise wreak havoc resulting in eventual alternator death...
Anyway, after coming across the info, I purchased a set of capacitors BETTER than the Radio Shack cheapees mentioned in the article. I have 3300 uF capacitors rated for 105 degrees Celsius (221 F). This should effectively double the dampening capacity of the installation the other guys used.
I am considering putting together a 1-stop upgrade kit for the R/R that would include everything including a custom mounting bracket waterjet cut from aluminum.
For those that are interested in the capacitors and have the other portions of the upgrade done, I can supply them go at $14 per pair + shipping. You can contact me [email protected]
itlnstln13 is offline
post #2 of 8 (permalink) Old 08-29-2006, 05:21 PM
Uber Member
14 a pair?!?!? radio shack for like 3 bucks per set. also why water jet cut aluminum. I prefer jigsaw cut :P
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 8 (permalink) Old 08-30-2006, 06:28 PM
Sky Rider's Avatar
More $$$$
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 8 (permalink) Old 08-30-2006, 08:41 PM Thread Starter
$3 for a set??
I will give more specific information:
16V 3300 uF rated at 105 Celsius (221 F) Radial Lead (both leads on same end, not axial)
Radio Shack provides nothing within these specs. The closest is a 4700uF rated again at the LOWER 60 Celsius temperature range axially mounted (more difficult to install).
I'll requote at $12 per set + shipping. Good luck trying to find anything similar at Radio Shack. I tried before I located these.
post #5 of 8 (permalink) Old 08-30-2006, 09:39 PM
tankist's Avatar
Send a message via Skype™ to tankist
will 12$ include this custom bracket? i can see the shipping charge around 7-10$ location dependent.
how these caps preform on in the long term? i mean they will be filled 24/7, they are not ideal there will be a current (even if very small) that will go through them . i woud also consider making a discharge sircuit (maintanence) so not to have to loaded hidg capacity caps while working on electrical system
http://agrasyuk.googlepages.com/home
Anton Grasyuk
Wheeling, IL
tankist is offline
post #6 of 8 (permalink) Old 08-30-2006, 11:04 PM Thread Starter
These capacitors are not like the large 1 Farad capacitors in high power car stereo applications. They are located on the power circuit between the R/R and battery.
The price is for the capacitors only. They are not large. About 3/4" diameter. I can place in small bubble envelope and mail for around $2-$3 I think. Haven't checked out furthest location yet or cost of shipping materials.
Capacitors always have a charge on them unless discharged.
The bracket would be extra. I have not yet had a chance to investigate this yet. You could replicate what the other guys have done with a simple piece of strapping steel, u-bolt, and associated hardware for now. I need a chance to sit down and design something in the computer, create prints and get quotes if feasible Will post more info on this later once I have a full kit figured out.
post #7 of 8 (permalink) Old 08-30-2006, 11:11 PM Thread Starter
To answer the previous quote regarding why waterjet cut versus jigsaw cut:
I need to provide consistency in fit,finish,function of the end product if I were to supply to people. Water jet is just like running a laser cutter without the problems of "attempting" to laser cut aluminum. Process is used in the aircraft industry extensively.
post #8 of 8 (permalink) Old 08-30-2006, 11:56 PM
95VN750's Avatar
Why water jet???? Hell... if I had access to toys like that I use them too!!!
1980 440LTD
1976 KZ900
1995 VN750 19,500 miles ( start of '08 season ) All mine!
Can't have too many Kaws!
95VN750 is offline
