Self healing VN 750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-29-2006, 04:29 PM Thread Starter
Tex
Self healing VN 750
Ok, maybe not self healing, but damn close. My bike wouldn't start before I went on vacation. I had the local shop do a load test on the battery before I left and it checked out. When I came back from vacation, everything started fine and I haven't had any problems since then. So, my thought is the load test fully recharged the battery and that I have a small energy leak (it got low after 3 or 4 years). I think some of it might come from a low idle while not in motion. What RPMs should I be idling at? I'm currently right at 1000.
I think I'll go through the ElectroSport fault finding flow chart too just to double check.
Also, my plugs might be the originals. Any preferences on plugs?
Thanks,
Tex
Tex is offline
post #2 of 10 (permalink) Old 08-29-2006, 04:31 PM
Rubline's Avatar
1k is where it should be.
Rubline is offline
post #3 of 10 (permalink) Old 08-29-2006, 04:36 PM Thread Starter
Tex
Thanks Rubline. I'll just change the plugs and try the flow chart then.
Tex
Tex is offline
post #4 of 10 (permalink) Old 08-29-2006, 04:57 PM
Once Banned
cegodsey's Avatar
Get the iridium plugs. A little pricey, but you'll never have to change them again.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #5 of 10 (permalink) Old 08-29-2006, 07:05 PM
Uber Member
well that is so long as you dont foul them up by running rich, or burn then by running to lean. I prefer regular old autolites....
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #6 of 10 (permalink) Old 08-29-2006, 09:56 PM
Never satisfied
Woody's Avatar
Tex, it could be possible that maybe you gad water in a connection and a short which dried out while you were gone. Kinda like in the "old days" if you got water in your distributer cap.
Jeff (Woody) Woodward
[B]'99' Black and blue(deceased)
06 900 Classic
MS shield&lowers
ISO flame grips
Mustang seat
Cobra backrest/rack
Phat II risers
Leatherlyke bags
Roadhouse 2 into 1's (wish they were made for 750's)
Scootworks pulley
Woody is offline
post #7 of 10 (permalink) Old 08-30-2006, 03:01 PM
Benjammin'
BSkaggs513's Avatar
I am an iridium guy myself. Changed out from originals, now cold and hot starts are amazing. If you change to the plugs- be sure to use anti-seize on the plug threads. True, if everything is running correctly, you never need to change them out, but a welded plug to the threads is no fun when and if you ever have to take them out.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #8 of 10 (permalink) Old 08-30-2006, 06:03 PM
Sky Rider's Avatar
Most likely your no start problem was a dirtly electrical connection since it seemed to "heal itself" after you had the battery load tested. I am assuming it had to be removed to do that. The reinstall probably cleaned the terminals and allowed full current to flow.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #9 of 10 (permalink) Old 09-02-2006, 12:49 AM
Butterman's Avatar
I just put new autolite 4164's in (I'm pretty sure that's the correct p/n). Runs like a champ. Plugs cost $1.89 apiece. At that price, I'll change them every year, or more. Check with local dealer to cross-over the recommended NGK # to autolite #.
Butterman is offline
post #10 of 10 (permalink) Old 09-02-2006, 01:09 AM
Once Banned
cegodsey's Avatar
The plugs are a choice that you have to make yourself, just like the battery. If you don't have any problems starting the bike, and your battery is shot, do you get another wet cell battery that has been working fine, or do you get the Maintenance Free battery? The second costs a lot more, but you don't have to check your water levels, and it will fix the hot start problem if you should happen to have/get it. Similar with the plugs. You can have regular inexpensive plugs that start the bike, but you have to change on occasion, or you can get the iridium plugs that never need changing (and everyone raves about), but are expensive.
Then you have your obligation to keeping people employed making plugs, or keeping excess plugs out of the dumps.
Your choice.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
