load equalizer - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-28-2006, 09:20 PM Thread Starter
load equalizer
hello all. I am planning on adding some running lights that are led lights. I also plan on replacing the taillight with an led so i will be able to get more out of my charging system to install a 20w lightbar. I've read I would need a load equalizer since the led lights do not require as much amperage. Anyone familiar with adding led lights and how do you install the load equalizer? thanks for the input.
proudvulcan is offline
post #2 of 3 (permalink) Old 08-28-2006, 09:51 PM
HAWK
Ccspinner's Avatar
The load Equilizer is if you are going to change your turn signals to LED. Otherwise they would flash very fast. I believe it is a stage of resistors to trick your flasher to see the same load as if it were a normal bulb.
I hope this helps.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 3 (permalink) Old 08-28-2006, 11:34 PM
Uber Member
You would be better off using a heavy duty flasher. load equilizers are as mentioned by Ccspinner. Issue is though that they burn some juice as heat to make the flasher think that the regular light bulb is in there. In effect you have no electrical gain from using these.
Now a heavy duty flasher will flash the same rate regardless of power draw. Hope that helps!!!
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
