Charging System Output Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 09-30-2012, 01:18 PM Thread Starter
Crap, I WAS in 5th gear.
I put in a TPE rewound stator and I'm seeing 12.4v at idle when hot, with the high-beam and fan on. My replacement R/R is giving worse results, as it is not as efficient as stock. The major stator lead tests appear to be fine (AC output, resistance, leg shorts and ground tests ok.)
Here's what I've done so far:
Replaced R/R connector
Cleaned battery ground
Added parallel wire from R/R white wire to positive battery terminal (added 0.3v)
Removed stator bullet connectors and soldered
Cleaned positive connections on starter relay and the bullet connection carrying charge current
I'm thinking that an R/R sense wire problem would drive higher battery voltage?
I'm going out to the garage now to run the full cold/hot troubleshooting analysis per Slims excellent guide, but would appreciate any feedback from you guys.
Kelly2001 is offline
post #2 of 7 (permalink) Old 09-30-2012, 01:34 PM
what r/r i you go with?
post #3 of 7 (permalink) Old 09-30-2012, 01:56 PM Thread Starter
I got one from a John Deere parts supplier that should be compatible. It appears that both R/Rs are bad. A1, A2, A3 to Batt are 4400 ohms. What are the frigging odds?
Going to get a MOSFET. I didn't really want to ride in SoCal anyways for several days, it's going to be 106 degrees here! Some say, "too hot to wear leathers, too hot to ride."
post #4 of 7 (permalink) Old 09-30-2012, 02:15 PM
Isn't the MOSFET R/R what I told you to go with originally Kelly?
post #5 of 7 (permalink) Old 09-30-2012, 02:46 PM Thread Starter
Preventive Maintenance
I'm sure you did, buddy! In hindsight, the best advice is to just replace the stock R/R with a TPE rewind and also replace the R/R with a MOSFET at the same time. Also, if you're not riding year-round and need a Winter project, just do both at 20k to ensure no unexpected down time.
post #6 of 7 (permalink) Old 10-01-2012, 03:21 PM
ifixf18s's Avatar
If your stator readings are good, and u plan on getting the mosfet R/R anyway. I'm thinking wait until you install the MOSFET and recheck your voltages. That sense wire will no longer be used with the MOSFET.
Also something to think about when replacing the R/R or maybe figured it out when replacing the stator. When I replaced mine I used the Original bike wiring for the stator and hooked it up to the bullets ( there soldered now). When I connected the R/R I used the wires from the old R/R connector. In a nut shell one leg of the stator wiring is spliced and goes to the JB for the head light relay.
I've seen on here where someone had headlight issues after replacing their stator because they wired it directly to the R/R.
But u mentioned removing the bullets and soldering, just mentioned this invade you didn't know about the spliced wire going the the JB.
ifixf18s is offline
post #7 of 7 (permalink) Old 10-02-2012, 01:15 AM Thread Starter
I got the MOSFET from roadster cycle. Thanks for the heads up on the headlight relay- I did remember. I'm still undecided, but will probably just use the wires out of the old harness to avoid tracking down the headlight relay wire.
