Headlamp issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 09-25-2012, 05:28 PM Thread Starter
Headlamp issue
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #2 of 3 (permalink) Old 09-25-2012, 08:37 PM
Originally Posted by FlacoLove View Post
After disconnecting a faulty voltmeter, which I had relayed off of the front driving/signal light, I no longer have headlight working (everything else is working). I connected the headlight direct to batt and she works.
I checked the fuses and this is where it gets weird. I connected a test light to the headlight connector up front and when I push in the headlight fuse, (with force) I get a light power reading, but when I reconnect the headlamp, nothing. I switched the fuses around, disconnected, cleaned, reattached the junction box, connected headlamp and applied force to the fuse but still no power to the headlamp (although I do get a light reading with testlight attached to the headlight connector, and to the two spots where the fuse connects.
Any ideas as to why my headlight don't function anymore? Do I need a new/used junction box? or any other connection to check? Ride safe.
try bending the blades on the fuse a little you may have streched out the connections in the jb if that isnt it you will be needing another jb
post #3 of 3 (permalink) Old 09-26-2012, 01:00 AM
Headlamp making good connection ?
Acts like a burn out Headlamp....I am sure NOTt !
Williamtech
