Headlight issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 09-20-2012, 09:11 AM Thread Starter
Captive New Yorker....
peterherrm's Avatar
Headlight issue
Hello all,
I noticed on my way to work yesterday that my headlight was out. What happens, is the headlight comes on normally when you first start the bike. Both high beam and low beam work fine, but after riding for about a minute, the headlight goes out, and does not come back on at all.
If I stop the bike and turn the engine off, and let it sit for a bit, then start the bike up, the headlight is back on again, only to go off again after riding for about a minute, and it never comes on again. All other lights seems to be functioning normally.
Any ideas where I should start to trouble shoot this? Bad headlight relay in the fuse box? How would I test for this?
Not sure if it is related, but I am also having an issue with the right blinker, its will blink very fast intermittently while riding. It never does it while the bike is parked. Might be related??
Thanks!!!
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #2 of 14 (permalink) Old 09-20-2012, 11:01 AM
Originally Posted by peterherrm View Post
Hello all,
Thanks!!!
Yes, as KC suggests, a thermal issue, start by cleaning the JB connectors, BUT most importantly clean ALL battery grounds . If no success... clean the Dimmer Switch contacts. Last resort, replace JB.
Blinker problem, definitely would look for a short in the appropriate connector. CLEAN ALL CONNECTOR CONTACTS.
hope this helps
WilliamTech
post #3 of 14 (permalink) Old 09-20-2012, 11:40 AM
fast blinker suggests you are losing a bulb connection on that side.
As far as the headlight....if it were me, I would start with making sure the stator wire going to the junction box is showing ac on it. check the bullet connectors if they are still in place. YOU WANT TO MAKE SURE YOUR STATOR IS GOOD!
It sounds to me like a thermal issue causing either the stator or a connection to fail.
If you still see AC on the 3 stator wires when the headlight goes out, then you can start checking connections from the JB to the light....including relays and switch connections.
post #4 of 14 (permalink) Old 09-20-2012, 10:32 PM Thread Starter
peterherrm's Avatar
Well I checked the stator output, that's fine. All 3 connections are also tight. The blinker problem was a loose wire.
I tested the bike again, and temp doesn't seem to effect it. I left the bike running for a long time, until it was very hot, and the headlight stayed on the whole time. Then I took the bike around the block, got it up to about 40 MPH, and the headlight stayed on the entire time.
Then I went out on the main road where I could open her up more, and once I accelerated fast the headlight went out. It then came on briefly, then went out again and never came back on.
I'm think what I should try next, is bypassing the headlight relay as described in a past post? I really don't want to replace the whole junction box....
Is the Head Lamp indicator light supposed to be lit the entire time the headlight is on? It was never on when I had my old instrument cluster, then I got a new cluster, and it also has never been lit. I assumed that both units had the bulbs burned out, but now I'm wonder if this is suppose to light up to worn you that the head lamp is out? If so, this light does not come on when my head lamp is out.
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #5 of 14 (permalink) Old 09-20-2012, 10:37 PM
__________________
the light is always supposed to be lit... light illumination means the headlight system is ok.. bright illumination means that either hi or low beam is burned out... depending on what position the dimmer switch is in.
post #6 of 14 (permalink) Old 09-20-2012, 10:46 PM
JM2001's Avatar
The headlight indicator bulb only comes on when either the low or high beam goes out.. The headlight reserve device automatically switches to the remaining good filament. You may just have a bad bulb.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #7 of 14 (permalink) Old 09-20-2012, 11:04 PM
romeobravo172
romeobravo172's Avatar
I agree, the white box only comes on to say a prob with the headlight! Just went down to garage and did a positive ck. Have had 2 750's and have never seen that light on the cluster come on. But also have not had a bulb failure either!
romeobravo172 is offline
post #8 of 14 (permalink) Old 09-20-2012, 11:14 PM
this shows that the light wile be lit dimly when both Hi and Low are working normal, Bright when either Low or Hi filaments are burnt out. If the light doesn't go on at all, then the headlight Relay inside the JB is either not working, or its not getting triggered by the Stator.
post #9 of 14 (permalink) Old 09-20-2012, 11:49 PM
It's true. The white light is usually on, just dim. It only shines bright when somethIngs wrong.
Just a shot in the dark here.... But it might just be a loose connection or a wire shorting in the headlight bucket. As mentioned.. Check all the connections.
post #10 of 14 (permalink) Old 09-21-2012, 02:14 PM
I agree with Slim and Knife....it is lit, but so dimly lit that you won't even realize it is on unless you are in pitch black.
It could be a loose wire in the bucket, but it could also be a bad bulb.
Does it do this on both hi and low beam??
Tags
headlight
