Another weekend, another problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-15-2012, 08:51 PM Thread Starter
originalbat's Avatar
So how do i go about finding a loose connection or wire without taking my entire bike apart? Riding fine, stoppped for fuel and had to jump her off. Put her to charge started fine. Next morning drove 40 miles to work, no problem. After work had to jump her again. Drove home, running just fine. Turned into subdivision and she kills. Pushed her home. Let her charge for 15 min., she turned over. Put her back on charge. After an hour, started fine at 12v, revved to 3000 rpms at 13.8v. So, by my logic, loose wire or connection, right?
originalbat is offline
post #2 of 6 (permalink) Old 09-15-2012, 10:19 PM
Mntsnow's Avatar
Replace the battery.....If you don't your going to kill your Stator & or R&R!
- Mntsnow -
1988 VN750 - Fixing up for my son!
Mntsnow is offline
post #3 of 6 (permalink) Old 09-15-2012, 10:38 PM
romeobravo172
romeobravo172's Avatar
Give batt a full charge, take it to local A-zone-P-Boys ect and have a load test done. Is a good way to know for sure if your batt is up to par. Also ck your ground connections, also ck your ground connections (and yes I meant to say that twice!!!) Don't just look at them but clean them GOOD.
romeobravo172 is offline
post #4 of 6 (permalink) Old 09-15-2012, 11:04 PM Thread Starter
Thanks for the feedback, bud. Will be checking everything tomorrow afternoon. Thanks again
post #5 of 6 (permalink) Old 09-15-2012, 11:32 PM
Check batt ground at frame.
post #6 of 6 (permalink) Old 09-16-2012, 06:21 PM Thread Starter
Took fully charged battery to Advance Auto, checked out fine. checked and cleaned ground connections. searched for skinned or bare wires. Found one, covered with electrical tape. I guess now I have to wait for better weather to take her on a test run
