Help needed - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 09-14-2012, 03:23 PM Thread Starter
92' Vulcan Rider's Avatar
Help needed
My 92' Vulcan 750 is running terribly. Two things are happening. As I ride it, it's trying to cut out. Also, (sometimes) I push the start button and nothing happens (it's just dead). A few pushes later and it starts. Both of these things seemed to start happening at the same time. Are they related? Any help is appreciated.
Thanks, Kevin
92' Vulcan Rider is offline
post #2 of 5 (permalink) Old 09-14-2012, 03:42 PM
Smile
Thanks, Kevin
Welcome to the forum.
Starting problems are _almost_ always a problem listed below.
1. Weak - Old battery, if buying new, buy AGM.
2. Poor battery cable connections. Clean both battery posts/cables.
Clean each/every battery cable connections @ Starter Solenoid, Starter,
and two frame grounds. The 2nd one is on the bottom of the engine
(Starter ground) (engine is mounted with rubber mounts).
3. Stator or R/R charging problems.
4. It is possible your ignition switch has worn/dirty contacts. A contact cleaning procedure is in the Verses.
5. It is also possible loss of spark momentarily, which may indicate electrical connector(s) issue (coil, junction Box connections).
or your cutting out problem may be/also sounds like possible carb issues.
hope this helps
WilliamTech
post #3 of 5 (permalink) Old 09-14-2012, 05:32 PM
I'm thinking it's Door #2....... Poor battery cable connections. Which would make it cut out and the starter not work.
I'd start there and then check all the other things if there are still problems.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #4 of 5 (permalink) Old 09-15-2012, 03:13 AM
AZvulcan17's Avatar
whenever my starter button doesn't do anything at all, usually just a quick drop of the clutch lever and then re-grabbing it makes it work. It could just be that easy. I don't know why it does that, but all my connections have been checked and are fine fine and clean. It's just a little old and grumpy.
~Andrew~
__________________________
Earshave
Whitewall Rear
Seat Trimmed
Guages Removed
Front fender gone, working on redesigning rear fender
Wish PO didn't get rid of horns, lol
De-goated, working on custom pipes
AZvulcan17 is offline
post #5 of 5 (permalink) Old 09-15-2012, 10:38 AM
Also check this for the starting issues. Just trying to narrow down the possibilities. As far as cutting out you could check the breather hose on the air intake box (right box I believe) and make sure it isn't bottomed out or out of its spot.
