Coil Relay Mod - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 08-25-2006, 01:40 PM Thread Starter
fergy's Avatar
Coil Relay Mod
Just curious if anyone has tried this coil relay mod on a Vulcan?
Obviously, our bikes only have a red, not a red/yellow as the KZ's have.
I did it on both my KZ's and it made a strong difference, especially on the 80 with all the crappy wiring. Wonder how it would impact hot starting issues?
It basically takes a new heavy gauge wire from the battery straight to the coil power (through the relay) and uses the old coil power to trigger the relay.
I don't see why it wouldn't work on the Vulcan. I'm thinking I might give it a go while I'm working on my r/r relocation this weekend...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #2 of 16 (permalink) Old 08-25-2006, 04:30 PM
My GS1100e and 650KZ are both set up that way,a little more juice from the coils never hurts. At least on a four cylinder classic .On twins I don't know.
Rob
rucruisen is offline
post #3 of 16 (permalink) Old 08-25-2006, 04:37 PM Thread Starter
fergy's Avatar
It just seems to me like you'd be going "the long way" to get to the same place by buying an MF battery to get better voltage to your coils. I still believe in the MF batteries, if for no other reason that the MF part, but I can't see that this could hurt anything, unless we have a computer on the bike that I don't know about.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #4 of 16 (permalink) Old 08-26-2006, 03:22 AM
Uber Member
i thought the ingition contol module did that. doesnt it adjust the timing for throttle and loads?
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 16 (permalink) Old 08-26-2006, 05:11 AM
Once Banned
cegodsey's Avatar
Yeah, how does that work? If the relay stays on all the time, then it's cool, but if the relay only kicks in with a fire signal, that's a no-go.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #6 of 16 (permalink) Old 08-26-2006, 05:55 AM
Hi!
It's connected to KILL switch, not to STARTER switch.
So the relay is still supplyied till you turn off the engine
with the KILL switch. It's very simple.
Thanks for the idea, FERGY ! I have had problems with
the ignition switch, and i hae to make such circuit.
Now i have simple connection from 30A fuse to kill switch
only for proper work. But i can turn the engine on without
the key ... With this circuit it will be the same, but i will
have much current for ignition coils, as it was said by RUCRUISEN
Regards!
kanclerz is offline
post #7 of 16 (permalink) Old 08-27-2006, 01:09 AM
Geek
rnewell's Avatar
There was nothing wrong with my stock battery, but I got a MF battery anyway. I can tell you that starting is much improved.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #8 of 16 (permalink) Old 08-28-2006, 01:52 PM Thread Starter
fergy's Avatar
OK guys, I did the coil mod. Did it along with my R/R Relocation this weekend and it works like a champ. If it weren't such a pain to remove my seat, I would have done them seperate so I could test the effectiveness against hard starting when hot. But, I didn't, so all I can say is that it works. Might have been my imagination, but seemed like I had a little more power going uphill. I let it get plenty hot after about a 15 mile ride, shut it off, sat for a couple minutes and fired it back up and it hit on the first sound of the starter. So, I guess time will tell. I changed the link in my sig to go to my Vulcan page with links to all the mods.
Side note, I drilled out the bolts from the top of the battery box, which took me about 10 minutes total time, including changing bits after my pilot hole and using my magnet on a stick to pick up all the shavings...
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #9 of 16 (permalink) Old 08-28-2006, 06:49 PM
Once Banned
cegodsey's Avatar
You didn't! Did you at least plug the holes? If you don't, you take a chance of losing all your electrons.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #10 of 16 (permalink) Old 08-28-2006, 07:09 PM Thread Starter
fergy's Avatar
Nope, didn't plug the holes. If I plugged them holes, the electrons would find some other hole to go up, hopefully not the one sitting on the seat at the time.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
