Headlight Shuts Off 4000 Rpm - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-25-2006, 10:07 AM Thread Starter
Have A 99 Vn750,headlight Shuts Off At 4000 Rpm.will Come Back On When Idles Down,and Touching Any Other Electrical Switch.including Brake Light.runs Great,never Have Starting Problem.
JOHNB279 is offline
post #2 of 5 (permalink) Old 08-25-2006, 10:56 AM
fergy's Avatar
Hi John, welcome to the forum!
Can you give a little more detail? Is the headlight turning off when you rev the bike to 4K while sitting still, or only while riding? Are you saying that if you squeeze the brake lever while revving at =>4K the headlight comes back on? Try to be as specific as possible when explaining the problem. Thanks!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 5 (permalink) Old 08-25-2006, 11:14 AM Thread Starter
It Will Shut Off Just Reving It Up.it Will Not Come Back On At 4k When Touching Brake,or Any Other Switch.the Headlight Out Minder Light Never Comes On Either.
JOHNB279 is offline
post #4 of 5 (permalink) Old 08-25-2006, 11:37 AM
Uber Member
check all connections....when i say this, pull them apart, look for corrosion and reconnect and make sure that the metal is a tight fit. to me it sounds like it may be a loose connection and the vibration of the engine is causing it.
You may also want to get a voltmeter or multimeter and check the charging voltage of the system at various rpms. Also it may be a bad lighting reserve unit. I think there is a post on the Y! forum on how to bypass it to see if that fixes it.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 5 (permalink) Old 08-25-2006, 11:40 AM
fergy's Avatar
Get some dielectric grease at your auto parts store and while you are finding/cleaning connections, put some grease in each of them to seal moisture out and hopefully keep them from corroding.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
