Battery Issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 29 (permalink) Old 08-21-2012, 07:35 PM Thread Starter
Rockstar187's Avatar
Battery Issues
The battery on my '97 keeps dying on me. She drives normal and fine and then all of a sudden she wont start. Starts to turn, then click click click. I've gotten a jump and it runs fine for about a week or so....then it happens again.
I currently have the fan on a switch hooked directly to the battery but I make sure to turn the switch off every single time I'm off of her. I even went as far as to not use the fan at all and she still died.
Any suggestions?
The battery is fairly new and the starter is brand new.
Rockstar187 is offline
post #2 of 29 (permalink) Old 08-21-2012, 07:40 PM
check all your grounds and do slimvulcanriders stator flow chart hat to say it but it may be time for a stator but do the flow chart first and check your grounds
also check the bullet connectors to the stator one may not be hooked in good
post #3 of 29 (permalink) Old 08-26-2012, 09:12 PM
any updates?
post #4 of 29 (permalink) Old 08-27-2012, 06:39 AM
Different bike, but star washers on my battery connections helped a good bit... Anyway an easy cheap try......
post #5 of 29 (permalink) Old 08-28-2012, 05:48 AM
wrench
Yamamoto's Avatar
what would be the best battery for the vn750 ?
the manual say's 12V 14Ah, i found normal and gel battery's for the VN.
what do you recommend ?
Yamamoto is offline
post #6 of 29 (permalink) Old 08-28-2012, 05:57 AM
I think most of us have had better luck with the MF Gel batteries... I know I have, and believe they are worth the bit extra...
post #7 of 29 (permalink) Old 08-28-2012, 06:04 AM
wrench
Yamamoto's Avatar
Thx,
i have a normal cheap one in it for the moment, since i need to start it no and then during the project.
Once it is finished (will take some time) i will opt for the better Gel version.
Yamamoto is offline
post #8 of 29 (permalink) Old 08-28-2012, 09:38 AM
Good one can be found Advanced Auto. I got the MagnaPower 12-Volt Sealed AGM. It's the ETX15L that has 220 Cold Cranking Amps. Got it in Jan of 2011 and haven't had any problems with it. Runs about $75 for it. Comes dry, got to add the acid and give it a 20 minute charge, but that can be done at most of the stores I I think.
MagnaPower ETX15L
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #9 of 29 (permalink) Old 08-28-2012, 09:58 AM
/\ What CW-4 said and here is another...
http://www.batterymart.com/p-Big-Cra...FQcGnQodQ1IASQ
It states free shipping, and will probably be no tax, depending...???
post #10 of 29 (permalink) Old 08-28-2012, 10:20 AM
And if you get one that needs charging, always good to give it a "top off" charge before the first use anyway, charge it at a slow rate. The battery will thank you for it later.
MCCT Mod
Pickup Mod
CW-4 is offline
