ignition Switch replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 30 (permalink) Old 08-17-2012, 07:52 PM Thread Starter
originalbat's Avatar
First off, Thanks for the help on my previous post. Now......Has anyone ever used the ignition switch wire harness to install a replacement ignition switch? I can buy a universal key switch from a local auto parts store for $15. The lowest price i've found online is $75 for an OEM part. Having a family and responsibilities i'm trying to save a few bucks. Any advice on the proper wiring would be appreciated.
originalbat is offline
post #2 of 30 (permalink) Old 08-17-2012, 10:08 PM
I had a diagram for that one too.. let me dig into my archives and post it up for you
post #3 of 30 (permalink) Old 08-17-2012, 10:16 PM
I thought I drew this up already... I will try to dig a little deeper for you and if I have to.. re-draw it.
post #4 of 30 (permalink) Old 08-18-2012, 01:43 PM Thread Starter
I've looked through your links.i haven't found anything. I would appreciate the help. Thanks
post #5 of 30 (permalink) Old 08-18-2012, 01:49 PM
it wouldn't ahve been in my links.. it would have been in a thread on this forum somewhere... just not sure which one.
post #6 of 30 (permalink) Old 08-18-2012, 04:32 PM
post #7 of 30 (permalink) Old 08-18-2012, 04:56 PM Thread Starter
Thanks, bud. I've also found this on a thread you helped someone else with:
slimvulcanrider
04-14-2012, 04:13 PM
i assume three prongs on switch are Ignition, Battery, and Accessory? If so the fallowing should do it for you. This also assumes you have a stock wiring harness.
Yellow= Ignition
Red= Accessory
Orange/Green strip = Accessory
White = battery
Red/Blue Stripe= Acessory
white/black stripe=Battery
Brown/white Stripe=Acessory
post #8 of 30 (permalink) Old 08-18-2012, 07:22 PM
thats it
post #9 of 30 (permalink) Old 08-18-2012, 07:30 PM
So, did you loose a key or has your ignition quit working. If it's the lost key, I now know for a fact the key code for your ignition is stamped on it.
post #10 of 30 (permalink) Old 08-18-2012, 08:34 PM Thread Starter
No, not a lost key. A key switch problem. Thanks to this forum i can fix it tomorrow
