Stator failing vs. R/R failing: Symptoms? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-12-2012, 03:18 AM Thread Starter
Let's Ride!!
DaveT319's Avatar
I don't know for sure that one or the other is going bad, but I suspect it could be happening (which would suck if it's the stator, cuz it's only had 10K or so miles on it). So how would I know which is the culprit? What are the symptoms associated which each parts failure?
DaveT319 is offline
post #2 of 3 (permalink) Old 08-12-2012, 03:25 AM
Ignore the symptoms, and just do the multimeter tests. No need to beat around the bush with speculation, this will tell you 100%.
See here.
post #3 of 3 (permalink) Old 08-12-2012, 10:32 AM
symtoms of a bad charging system... the battery goes dead, hard starts, dies on you about 15 miles from home and need a tow to get back home. once you have any one of these symptoms you need to do the test that ThTanner linked to.
