no headlight - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
LinkBack Thread Tools
Old 08-11-2012, 07:15 PM Thread Starter
Just a regular guy
Chris32250's Avatar
no headlight
I noticed yesterday before work.. my headlight isn't working. My signals and running lights work. I tried to take it apart and look at the bulb and it looks ok, although I couldn't get it completely out. Does the headlight and running lights work off a different fuse? and where is the fuse box on these bikes? any help would be great.
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Chris32250 is offline
Old 08-11-2012, 07:31 PM
Headlights are triggered off a stator lead.
Fuse box is under the left-hand side cover (or is it right? lol) It's behind a side cover.
If you don't see any fuse issues, you may want to check your charging system. The stator could be going south, but it's too early to make that suggestion.
Old 08-11-2012, 07:58 PM
check the blue wire in the 8 pin connector on the side of the fuse box for power while the bike is running.
if there is no power you have a bad headlight relay which is built into the fuse box and can not be replaced.
a temp fix for that is to pull the blue wire out of the 8 pin connector and push it into the empty slot on the same connector this bypasses the headlight relay and your light will come on as soon as you turn the key on
hope this helps
Old 08-11-2012, 08:17 PM Thread Starter
Just a regular guy
Chris32250's Avatar
My light has always come on when the key is turned.... that isn't normal?
===2001 Vn750====
Ears shaved
Sportster pipes
Old 08-11-2012, 08:21 PM
nope that means it isnt the relay because it is already bypassed check for power at the blue wire where it goes into the fuse box
also0 have you tried turning the high beam on and see if it works if it does then you could just be dealing with a bad bulb
Old 08-11-2012, 08:26 PM Thread Starter
Just a regular guy
Chris32250's Avatar
Yeah, I tried the highs. They are out. Another thing... my headlight indicator has never came on.... I didn't pay much attention till now.
I will have to check for power tomorrow, it's dark here and I don't have a garage. Plus my meter is in my car which my sister is using. But I will see what I can do tomorrow...
===2001 Vn750====
Ears shaved
Sportster pipes
Old 08-11-2012, 08:38 PM
these vulcans do have a bad case of electrical gremlins kinda wish that was my problem but im not that fortunate i got the short end of the mechanical stick lol
Old 08-11-2012, 09:45 PM
Check the fuse...
Old 08-11-2012, 10:03 PM
It will come on and stay on if youve tapped the starter button...makes no sense to me, so if the battery is low, the light will drain it more whilst trying to start...I may put a switch inline to prevent that....stupid design....they couldda made it (fer safety) so's it comes on in all gears besides neutral...
Old 08-11-2012, 10:08 PM
Wolfie does your light come on when you turn your key on? Simple solution... wire the blue wire up to a relay.. some one bypassed he relay inside the JB because it was more than likely defective.
