Help! running lights not working - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 12 (permalink) Old 08-10-2012, 04:38 PM Thread Starter
my front turn signal running lights are on and working when bike is running but my rears aren't. The neither is my tail light. The rear turn signals work when the switch is engaged though. also the brake light works when i push the foot pedal but not the hand brake. What is going on?!?!?!?!
JRyanM383 is offline
post #2 of 12 (permalink) Old 08-10-2012, 04:54 PM
check your fuses
post #3 of 12 (permalink) Old 08-10-2012, 05:07 PM Thread Starter
Checked all fuses, nothing blown, did a visual inspection of wires under the seat and nothing there either
post #4 of 12 (permalink) Old 08-10-2012, 05:22 PM
JM2001's Avatar
Fronts are running lights AND turn signals. Rears are only turn signals. There are 2 bulbs in the tailight. Your running light bulb may be blown. There is a brake switch in the hand brake lever. It might be bad.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 12 (permalink) Old 08-10-2012, 05:27 PM Thread Starter
didn't know that about the rear turn signals, never really noticed, checked the bulbs in the tail light and they are ok, changed them for giggles and still nothing, i will check the hand lever switch.....tail light really stumping me though
post #6 of 12 (permalink) Old 08-11-2012, 05:19 PM
There is a connector under the seat connecting the harness to the rear tail/running/blinkers.
Make sure that connector is in good shape.....and check your wiring for exposed leads shorting under the seat area.
post #7 of 12 (permalink) Old 11-23-2017, 01:05 PM
Ok Iím having the same problem with my 98 classic. Only difference is my tail light works but it doesnít work when I engage the brake. Iíve checked all the wires and fuses several times. Is there a relay switch I could be missing? Did you ever solve this issue? I canít seem to figure it out.
Drifter23 is offline
post #8 of 12 (permalink) Old 11-23-2017, 01:27 PM
Does the tail light go out when you apply the brakes or are you just saying the brake light itself isn't working?
It's a duel filament bulb, did you try a new bulb?
post #9 of 12 (permalink) Old 11-23-2017, 03:29 PM
While the bulb may be the problem, I am willing to wager a turkey drumstick that the bike in question is not a VN750. if thats the case, the other Vulcans are totally different in all regards from the 750
OleDirtyDoc likes this.
post #10 of 12 (permalink) Old 11-25-2017, 02:28 AM
yup yup Teddy bear, I've never heard of a vn750 classic. now Drifter (hmmmmmmm,maybe a vn800 with that thar screen name?), how about an introduction in the newbie section?
