switching off, - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-07-2012, 02:03 PM Thread Starter
switching off,
Key slot on Ignition switch on this 750 is loose,
and sometime's kill's the bike if it get's bumped.
find a good one on here if anyone has one.
kansaskirk is offline
post #2 of 8 (permalink) Old 08-07-2012, 02:31 PM
You can take them apart and clean them you know.....
post #3 of 8 (permalink) Old 08-07-2012, 03:11 PM
romeobravo172
romeobravo172's Avatar
Would it be the key slot or the Puck itself? Dosn't the key just turn a switch on the puck and drop the locking pin? I guess the little turn meck could be warn.
romeobravo172 is offline
post #4 of 8 (permalink) Old 08-07-2012, 03:28 PM
I believe the lock part just turns freely and the indents to hold it in each position are part of the switch. Hence my suggestion to take it apart and clean it.....as one will discover if something is broken and possibly fixable, or just packed with dirt causing it to not to hold in the various positions.
post #5 of 8 (permalink) Old 08-08-2012, 12:26 AM
romeobravo172
Please clue me in, does the actual key mec come apart? Does not look like a serviceble part to me!
post #6 of 8 (permalink) Old 08-08-2012, 01:53 AM
It does come apart. They are pretty easy to take apart. You will need to remove the entire switch assy. Then there are 2 small screws holding the puck on, and you slide it off to the side and you can get to the assy. on the bottom and clean it.
Mine did the same thing, and after I cleaned it I stretched the springs ever so slightly and put a dab of grease in there to keep the contacts clean.
You will need to be careful as there are small parts in there. Springs, balls, and contacts. Took me about an hour from start to finish to do mine. So far it has worked great for me.
TSmith68 is offline
post #7 of 8 (permalink) Old 08-08-2012, 11:09 AM
romeobravo172
I knew the Puck would come off, just wasn't sure the cylinder mec was serviceable.
post #8 of 8 (permalink) Old 08-08-2012, 11:39 AM
ahh y'all are doing it the hard way just bypass the switch and put a toggle on it lol
anyone knowing about the charging systems on these things would know if it gets stolen they aint getting far lol
just playing guys i love my vulcan
