Ignition Switch Problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 08-05-2012, 01:47 PM Thread Starter
originalbat's Avatar
Thumbs down Ignition Switch Problem
I bought a used '98 Vulcan750 over a year ago. Since then its been one little problem after another. I replaced r/r using a '94 750 i bought for parts. Now its a new problem. My bike starts fine but when I switch the key to the run position the bike dies immediately. Turned it back to START pos. and went for a spin, after riding for 2 -3 minutes I realized bike wasn't in RUN pos. turned key and bike died again. checked KILL switch its on run. kickstand is up. been trying to do fix this problem for last week or two. Anyone have ideas?
originalbat is offline
post #2 of 20 (permalink) Old 08-05-2012, 02:58 PM Thread Starter
Still fiddling with bike. Wanted to add... when I switch key to RUN pos. and riding twisting the throttle doesn't do anything.
post #3 of 20 (permalink) Old 08-05-2012, 03:15 PM
My Ignition key has "Lock, Off, On, & Park" switch positions. No "Run".
My Kill Switch has "Off" & "Run"
a little confused here...
WilliamTech
post #4 of 20 (permalink) Old 08-05-2012, 03:29 PM
Ceal's Avatar
Have you thought about leaving it in the "start" position? If I understand your post right, I think that's the way it's supposed to work!
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #5 of 20 (permalink) Old 08-05-2012, 03:43 PM
The key is supposed to be in the run position. You turn it to the run position, then hit your starter button.
These are a little bit different to a cars ignition switch. Our bikes don't have a momentary starter switch in the key switch itself.
Please don't take any offense from any of us, we aren't saying anything bad towards you.
I tried that the first time I had a bike with a key switch.
TSmith68 is offline
post #6 of 20 (permalink) Old 08-05-2012, 04:03 PM
JM2001's Avatar
WilliamTech
X2 Just leave the switch in " on " position and hit the starter button.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #7 of 20 (permalink) Old 08-05-2012, 05:43 PM Thread Starter
Thanks for all the help. I feel I need to clarify. After reading the posts I went re-look at my bike. It seems I've been starting my bike between the OFF and the RUN position. Bike starts fine, even operates in that key position; however, unless I switch to RUN i have no turn signals, no lights at all. Is it possible to re-wire my lights and turn signals to use a toggle switch to get them on?
post #8 of 20 (permalink) Old 08-05-2012, 07:12 PM
How about just rebuilding and cleaning the switch.....
there is a thread on it here someplace....
dariv is offline
post #9 of 20 (permalink) Old 08-06-2012, 12:04 AM
post #10 of 20 (permalink) Old 08-06-2012, 08:24 PM Thread Starter
Thanks
Again, thanks for the help and advice. It will be a weekend or two but i'll repost when i'm done
