What HID kit to buy - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-02-2012, 02:51 AM Thread Starter
What HID kit to buy
I want to get the H.I.D kit for my 750 hid for both high and low beam but i would like some advice on what kit to get since there are different vendors and different prices
cdlegate is offline
post #2 of 7 (permalink) Old 08-04-2012, 01:30 AM
I don't think our bikes have enough power to run HID. Best thing you could do is get a SilverStar head lamp. The bike only has 70 watts available which I find is too little for a cruiser. The KLR's have 200 watts. What the heck is a KLR gonna need that much power for? Too bad the stators aren't interchangeable. Would be cool to see higher wattage being produced for accessories.
post #3 of 7 (permalink) Old 08-04-2012, 08:38 AM
Deviate's Avatar
Here is a thread for you to read up on, lots of good info: https://www.vn750.com/forum/showthrea...ht+replacement
Not sure if those links to the kits will still work, but it may give you some idea what to search for.
Deviate is offline
post #4 of 7 (permalink) Old 08-04-2012, 09:08 AM
We have been running HID kits on our bikes here for quite a while without ill reports. as for high output charging systems, that is why I recommend a TPE stator coupled with a MOSFET R/R and a AGM battery. If you have Tim rewind a high output stator and couple it with a MOSFET R/R you can double the charging capacity, but you need to get a battery that can hold the extra juice for when all the accessories are not in use.
post #5 of 7 (permalink) Old 08-04-2012, 09:26 AM
I've been running a hid for a year now. No issues. Most typical HID systems only use about 35w which is less that our stock low beam. I bought a kit off ebay that was a hid halogen combo. I never turn the hid off, it runs as the low beam & I concider the halogen a back-up.
Make the jump, You'll Love It!
(I have know idea who I got it from, but they did have a life time warranty on the components)
post #6 of 7 (permalink) Old 08-04-2012, 11:06 AM
maybe it was just the hid i was running but i think the silverstar is well not brighter but it seems to project the light farther
post #7 of 7 (permalink) Old 08-04-2012, 03:05 PM
Drive less, ride more...
theauhawk's Avatar
Another option here is simply save up your nickels and dimes, and wait a while for the price of LED lamps to come down.
HIDs put out lots of light, but they usually have a "ballast" system on them as part of their start up, and this ballast is of course just something else to eventually fail, and leave you without a light when you really need it.
LEDs, on the other hand, have never needed a "ballast", are designed for super-long life (usually 50k hours or so), and are also designed to tolerate the high-vibration environment that motorcycle duty includes. They will generally draw less power than HIDs, as well. LEDs don't burn hot, either. And besides, they just look cool!
I know currently of at least 2 LED kits that are designed for motorcycle driving light duty (one of them even has a dimmer switch or dial), but they are pricey. It's simply a matter of time b4 the aftermarket world is offering more of these, at lower cost.
'05 VN750
theauhawk is offline
