Starting issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 30 (permalink) Old 07-31-2012, 02:39 PM Thread Starter
hwyenginr's Avatar
Starting issues
Ok so I just purchased a 1992 Vn750 with 14000 on it. It has sat for the most part of the last five years with the exception of being ran around the block every couple of weeks. It started great when I looked at it on Sat. put it in the truck to come home on Sun now it acts like the battery is dead, even though I installed a new battery and let it charge overnight. When loading it in the truck it bottomed out a little due to the ramp being a little to steep. Any suggestions as to what's going on
Thanks
92 Vulcan 750
Saddle Bags
Extended Backrest
ProTac Drivers Backrest
hwyenginr is offline
post #2 of 30 (permalink) Old 07-31-2012, 02:54 PM
romeobravo172
romeobravo172's Avatar
Start with cking your ground connections, start with the batt ground to frame. Are you getting any power at all? Turn switch on does anything happen, or nothing.
romeobravo172 is offline
post #3 of 30 (permalink) Old 07-31-2012, 03:24 PM Thread Starter
hwyenginr's Avatar
When I turn the switch I get all lights and it acts like it's trying to turn the starter just it grrs a little then clicks, but all light are working good and bright. It started right away Sat. no problem at all
Thanks
92 Vulcan 750
Saddle Bags
Extended Backrest
post #4 of 30 (permalink) Old 07-31-2012, 03:33 PM
romeobravo172
Also ck your engine ground to the battery box. Those ground connections can look ok but still not making a good contact. Do you have a volt/ohm meter? That can tell you a lot. Take the batt to the auto parts store and have a load test done, that is about the only way to see if batt is good. And yes, a brand new batt straight out of the box can be bad!! I bet it is prob a simple solution!
post #5 of 30 (permalink) Old 07-31-2012, 04:07 PM
Thanks
__________________
94 Vulcan 750
Is it possible you damaged the three Stator Wires...thus not charging ?
just a thought...
WilliamTech
post #6 of 30 (permalink) Old 07-31-2012, 04:45 PM Thread Starter
hwyenginr's Avatar
I'll check the stator wires but the bike started acting up when I took it out of the truck at home. Thanks foir the input and keep it coming. Can't wait to get the bike going while the weather is nice
Thanks
92 Vulcan 750
Saddle Bags
Extended Backrest
post #7 of 30 (permalink) Old 07-31-2012, 04:59 PM Thread Starter
hwyenginr's Avatar
Oh by the way I do have a multi meter, just being a noob to bikes don't really know where or what to check. Accepting all guidance from the knowledgeable members here.
Thanks
92 Vulcan 750
Saddle Bags
Extended Backrest
post #8 of 30 (permalink) Old 07-31-2012, 05:03 PM
Jump it off of the car batt, if bike starts, the batt and or charging system may have a problem.
post #9 of 30 (permalink) Old 07-31-2012, 06:08 PM
Thanks
When boosting off a car battery, Do NOT have the car running ! !
WilliamTech
post #10 of 30 (permalink) Old 07-31-2012, 06:24 PM Thread Starter
hwyenginr's Avatar
Ok thanks for the info, that is one of the few things however I did know. Damaged stator wires wouldn't run the battery dead if the bike wasn't running would it.
92 Vulcan 750
Saddle Bags
Extended Backrest
