Speedo didn't work, then it did, now it doesn't - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-24-2012, 07:14 PM Thread Starter
Finally got the 86 (no longer a knocker) up and running with the replacement engine. Only one strange thing: when I first took off with it, the speedo didn't work. Then on the third "recon" ride, the needle popped to life! I rode it for 150 miles, fixed a small oil leak at the oil switch, and the speedo hasn't worked since. Which I found pretty funny. (Maybe it like the leak!)
Anyone else ever had one come and go like that? I don't hear any funny noises, and I've yet to check the cable.
Jacknh is offline
post #2 of 7 (permalink) Old 07-24-2012, 07:24 PM
romeobravo172
romeobravo172's Avatar
I would suspect the sender is sticking or going bad. Unscrew the spedo cable from the sender(left side of front wheel) and attach the cable to say a cordless drill (sorry do not know which way it turns) and see if spedo comes to life. Ck both ends of cable and make sure they are tight.
romeobravo172 is offline
post #3 of 7 (permalink) Old 07-25-2012, 02:21 AM
violator80's Avatar
I just went thru the speedo issue, check here for some good info
https://www.vn750.com/forum/showthread.php?t=22210
also if you do have to order a new sender be sure & get the receiver as well.. its a cheap part but mine was roached!
1996 KAW VN750
Ricks Mororsports Stator & R/R
Vance & Hines Cruzers
Memphis Shades Memphis Fats Bobbed Gradient Black Windshield
Kuryakyn ISO Grips
NO MODS - I ain't gunna cut things that weren't meant to be cut on!
violator80 is offline
post #4 of 7 (permalink) Old 07-25-2012, 02:24 AM
violator80's Avatar
BTW here are some part #'s of interest for ya.
54001-1029 CABLE,SPEEDOMETER
41064-1006 RECEIVER,SPEEDOMETER
41078-1024 CASE-ASSY-METER GEAR
92033-1041 CIRCLIP,42MM
1996 KAW VN750
Kuryakyn ISO Grips
post #5 of 7 (permalink) Old 07-26-2012, 10:54 AM Thread Starter
Thanks guys, I'll dig into it this weekend and see what I can come up with.
Jacknh is offline
post #6 of 7 (permalink) Old 07-29-2012, 10:36 AM
Okiebezer's Avatar
Similiar issue
My speedo just stopped completely on my way home Friday afternoon. I checked the forum that evening for ideas. I have been extremely busy, so was only just able to take a quick look this morning. Much to my surprise (and relief) I noticed the issue right away! The cable had simply worked its way loose and was completely detached from the base of the speedo. 5 minute fix!
Okiebezer is offline
post #7 of 7 (permalink) Old 07-29-2012, 11:19 PM
violator80's Avatar
Phew that was close! Good deal!
1996 KAW VN750
Kuryakyn ISO Grips
