wont stay running - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-14-2012, 01:51 PM Thread Starter
wont stay running
I jumped my bike off with my truck (the truck was off) but as soon as I unhook the jumper cables it dies. The battery is new. Any help would be appreciated. Thanks
bryce23 is offline
post #2 of 11 (permalink) Old 07-14-2012, 02:02 PM
check your grounds... you have one on the frame under the seat, and one on the right hand side of the battery box that goes to the engine. It sounds like the Battery Box to engine ground is loose.
After checking your grounds, try jumping it off the truck again, but this time leave it hooked up to the car battery for about 5 minutes, let the bike idle and rev up to 2500 rpms during this time. then unhook the jumper battery and see if it stays running
post #3 of 11 (permalink) Old 07-14-2012, 02:09 PM Thread Starter
I will try that thanks
bryce23 is offline
post #4 of 11 (permalink) Old 07-14-2012, 03:03 PM Thread Starter
Tightened the grounds and rev'ed at 2500 for about 5 min still did not work. This guy in my apt complex came over to help and noticed my r/r was real loose looks like its about to fall off and probably not grounding like it should against the battery box. Does the r/r ground off the battery box? I'm gonna try that. any other suggestions to try
bryce23 is offline
post #5 of 11 (permalink) Old 07-14-2012, 05:19 PM Thread Starter
Ok I tightened the r/r and jumped it again still does the same thing.
bryce23 is offline
post #6 of 11 (permalink) Old 07-14-2012, 06:20 PM
yeah..R/R should get it's ground from the connector...didn't think that would matter.
Start looking over all connections including the 3 bullet connectors from the stator.
It sounds like your battery is dead and not charging.....can't think of a blown fuse causing this, but might be worth looking at the fuses and see if anything looks suspicious.
post #7 of 11 (permalink) Old 07-14-2012, 06:23 PM
...at this point, neither you or us know what your battery and stator condition is. Put a meter on the battery, if it is below 12.3 - 12.6 Volts, charge it.
Test your Stator/RR output. With engine running, rev @ 2K, voltage at battery should measure 13.6 volts or more.
If the readings above are not as stated the problem will slap u in the face.
hope this helps
WilliamTech
post #8 of 11 (permalink) Old 07-14-2012, 07:01 PM Thread Starter
It will probably be Monday until I can get a multimeter to check it so I will post back then. So I'm guessing bad battery or bad stator. The battery is not a mf and is it possible I could have killed it from multiple chargings/jumps fixing the not starting at all problem I was having?
bryce23 is offline
post #9 of 11 (permalink) Old 07-14-2012, 07:09 PM
Anything is possible...mc batteries do not seem to last as cage batteries do.
Plus, the VN750 can/will/does give many symptoms/problems with a weak or defective electrical system.
hope this helps
WilliamTech
post #10 of 11 (permalink) Old 07-16-2012, 05:27 PM Thread Starter
Just got done checking stator from bullet connectors engine off
Leg 1 to ground .09
Leg 2 to ground .18
Leg 3 to ground .01
Guess I need a new stator
Thanks for the help I might need more while doing the tuxedo mod
bryce23 is offline
