cold starting and idleing problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 07-12-2012, 10:37 AM Thread Starter
Hey everyone, I have been fighting a problem for quite a while, When I first start my 1993 vulcan the rear cylinder doesnt fire, if I rev it up it will fire, and after it warms up it runs fine and idles at 1100 rmp. I am getting plenty of gas, I pulled a plug and turned it over and the spark seems great. I have put iridum plugs in it. and changed the rear plug wires. If it was a fuel problem wouldnt it happen all the time not just when its cold. any advice would be appreciated
Tony D. is offline
post #2 of 14 (permalink) Old 07-12-2012, 10:50 AM
Have you checked the carbs for clean pilots, appropriate float levels, and performed a sync?
post #3 of 14 (permalink) Old 07-12-2012, 10:54 AM
I had rear cylinder firing intermittently, cleaned all coil connections, connector plugs and Ignitor connector...no help.
I replaced the Ignitor Box...problem resolved.
I have also added a relay which places battery 12 -13V directly onto the coils, thus no loss (voltage drop) through bike electrical harness.
WilliamTech
post #4 of 14 (permalink) Old 07-12-2012, 12:27 PM
https://www.vn750.com/forum/showthread.php?t=17276
Hope this helps
WilliamTech
post #5 of 14 (permalink) Old 07-12-2012, 12:44 PM
I had the same issue until I dumped half a can of seafoam in. It idles just fine cold now. I still have to choke it to start it, but I accept that.
post #6 of 14 (permalink) Old 07-12-2012, 05:04 PM Thread Starter
just replaced my ignitor with one from a friends bike, and unfortunatly it didnt change a thing. I have been trying to avoid taking the carbs out but I guess I have tried everything else. so thats what I will do next. thanks guys.
Tony D. is offline
post #7 of 14 (permalink) Old 07-20-2012, 05:36 PM Thread Starter
well just finished removing and cleaning the carbs, also did a sync. still no change. could it be an internal engine problem
Tony D. is offline
post #8 of 14 (permalink) Old 07-20-2012, 06:00 PM
Hey everyone, I have been fighting a problem for quite a while, When I first start my 1993 vulcan the rear cylinder doesn't fire, if I rev it up it will fire, and after it warms up it runs fine and idles at 1100 rmp. I am getting plenty of gas, I pulled a plug and turned it over and the spark seems great. I have put iridum plugs in it. and changed the rear plug wires. If it was a fuel problem wouldn't it happen all the time not just when its cold. any advice would be appreciated
I still say it's electrical.............
I have also added a relay which places battery 12 -13V directly onto the coils, thus no loss (voltage drop) through bike electrical harness. WilliamTech
Read Post #10 & Post # 12 in the following link:
give it a shot
hope this helps
WilliamTech
post #9 of 14 (permalink) Old 07-20-2012, 07:50 PM Thread Starter
thanks for all your help William. I know you have posted to my questions in the past, and I appreciate it. I will give this mod a try, I have been thinking its electrical from the start, but this is my first bike and I didnt know where to start. So thanks again and I will keep you posted.
Tony D. is offline
post #10 of 14 (permalink) Old 07-20-2012, 07:55 PM
Replacing the Ignitor cured my problem. They are not that expensive.
WilliamTech
