Charging System Problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 07-11-2012, 08:56 AM Thread Starter
I just purchased a 1986 VN750A. The bike is in great shape but it is having some charging issues. I have replaced the battery, reg./rectifier (twice) and the stator checks out at .40 ohms between all legs. I checked all of the related wire connections starting with the 3 stator leads all the way back to the positive post of the battery. Everything checks out fine yet when I start it and check voltage across the battery posts it only reads 11.7 -11.9v from idle all the way up to 4K rpm.
The last two possible causes I can think of are the rotor magnets just do not have enough magnetic flux density any more to give a sufficient charge or the new battery (installed by the previous owner) has been deep cycled several times during the process of testing various fixes.
Any help would be greatly appreciated as I am at my wits end in figuring this out. Thanks.
Var1000 is offline
post #2 of 21 (permalink) Old 07-11-2012, 10:54 AM
I think it is the stator. Slim will jump in here and let you know how to test stator for amp while engine is running.
post #3 of 21 (permalink) Old 07-11-2012, 11:19 AM
Fallow this thread's links (Click Here) and fallow my flow chart.. fallow it step by step filling in every blank line, and repost the results exactly as I have them laid out. by doing so, I can help pin point exactly what is going on.
post #4 of 21 (permalink) Old 07-11-2012, 11:28 AM
X2 /\ /\
Fill out the test sheets that Slim laid out FULLY and completely.
The whole procedure will tell things that might be missed otherwise.
post your findings and we should be able to point you in the right direction.
post #5 of 21 (permalink) Old 07-11-2012, 11:38 AM
^ as above.
My assumption is the stator is grounding out. Check for that and run the AC voltage tests on his procedure to confirm. The joy of the VN750 stator...
post #6 of 21 (permalink) Old 07-11-2012, 12:23 PM
Chuck A.'s Avatar
Stator. And you'd be money ahead if you send it to TIM PARROTT ENTERPIZES for a rebuild.
Chuck A. is offline
post #7 of 21 (permalink) Old 07-11-2012, 12:24 PM Thread Starter
Thanks for valuable input. I will fill out the sheet with meter readings this evening and post results here.
Var1000 is offline
post #8 of 21 (permalink) Old 07-11-2012, 07:56 PM Thread Starter
Slim - attached are my test readings. I wont bias any feedback by stating my observations so just have a look and let me know what you think.
Var1000 is offline
post #9 of 21 (permalink) Old 07-11-2012, 08:10 PM
no attachment bud
post #10 of 21 (permalink) Old 07-11-2012, 08:25 PM Thread Starter
I just realized that the attachment did not attach. The .pdf is too big and I do not have a photobucket or any other sort of hosting site to put them in. Any suggestions on how to get the file so you can take a look? Thanks.
Var1000 is offline
