headlight issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 07-10-2012, 09:19 AM Thread Starter
knees in the breeze!!!
Tofer76's Avatar
Question headlight issue
so i noticed yesterday that my low beam is very weak and the high is fine .
the high beam indicator is on all the time too weak when im on low beam and bright when on high beam.
my voltage gauge shows 14v at idle and drops to 13,5 when reved up and riding down the road
when riding with low beam 13.5
switch to high and the v go up to 14-14.4
this just started yesterday
my headlamp is not the stock one but is a identical replacement with clear lens and bulb came with
any ideas on what to check
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #2 of 20 (permalink) Old 07-10-2012, 09:47 AM
Did you check the bulb connection?
post #3 of 20 (permalink) Old 07-10-2012, 10:56 AM
something sounds fishy here.....when did you replace the headlight?
is it possible that one element is burned out and the headlight bypass is active?
either that or something seems to be shorted out wired incorrectly.
post #4 of 20 (permalink) Old 07-10-2012, 10:58 AM
is the white light on the dash lit up? if so the Reserve Lighting Unit is active and you need to change the bulb.
post #5 of 20 (permalink) Old 07-10-2012, 11:05 PM Thread Starter
Tofer76's Avatar
no no white light on the dash. it has never came on ever. i put the light on this last winter . it has worked fine till now . how exactly does the reserve lighting unit work
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
post #6 of 20 (permalink) Old 07-10-2012, 11:17 PM
Check your hi-beam/lo-beam switch on the handlebar. Sounds like a short in the switch.
You could have current bleeding through the switch.
TSmith68 is offline
post #7 of 20 (permalink) Old 07-12-2012, 11:24 PM Thread Starter
Tofer76's Avatar
checked bulb connector and its good
cant see anything else out of place
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
post #8 of 20 (permalink) Old 07-13-2012, 01:03 AM
Ndr
Have you tried putting in a new bulb to see if that solves the problem? Perhaps your reserve lighting unit is active and the bulb is blown so you don't actually know its active.. I suppose the likelihood of that exact scenario is a bit slim, but ya never know. It far easier to change a bulb, then to tear apart the switch to look for a short.
Put in a brand new bulb. if that fixes the issue, then the old bulb is at fault. If the new bulb changes nothing, then you have some digging around to so with the wiring.
Ndr is offline
post #9 of 20 (permalink) Old 07-13-2012, 09:17 AM Thread Starter
Tofer76's Avatar
I ordered some on ebay but it will be a while before they r here. How does the reserve light unit work. Does it turn the high beam on a little bit when the low burns out?
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
post #10 of 20 (permalink) Old 07-13-2012, 09:31 AM
Someone correct me if I am wrong....
I believe reserve unit ensures hi or low beam shines...should one or the other burn out..... when this happens, the "White" indicator light turns on alerting you to a headlight problem.
hope this helps
WilliamTech
