Charging system - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-30-2012, 02:01 PM Thread Starter
Charging system
95 degrees and, at 75 mph, just keeping pace with traffic for approx. an hour....temp needle pointed straight down in gauge....Voltmeter happy.
Pull up to stop light and notice charging system isn't charging at idle...rev it up to 2K...still not charging....light turns green...off we go...system starts charging approx. 3K. Everything running fine but I'm curious....next light same thing. Get to destination and let the bike cool down....start it up...charging at idle.
Conclusion....for reasons I hope someone here can explain, the charging system is not as effective when bike is hot....just fine when cool. What does this indicate??
VoIPDoc is offline
post #2 of 11 (permalink) Old 06-30-2012, 02:09 PM
Have you relocated your R/R? If not, that would be my first step! It sits right above the goats belly by default, which gets really hot.
There are tons of different relocation threads that are done differently. Just do a quick search and you'll find tons of info!
post #3 of 11 (permalink) Old 06-30-2012, 03:37 PM Thread Starter
Ah, no need. GB came off day one when Cruzers were installed.
Thanks.
VoIPDoc is offline
post #4 of 11 (permalink) Old 06-30-2012, 04:08 PM
pittdave's Avatar
Im in the same boat and notice the same thing. Ive asked the same question about the R/R and Cruzers. Its been said the R/R still gets plenty hot even with the GB gone. Haven't moved the R/R yet but probably will soon
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #5 of 11 (permalink) Old 06-30-2012, 04:14 PM
JM2001's Avatar
Your fan is probably coming on at the stop light drawing extra amps, then when you get to 3000 rpms the air flow is cooling the radiator and the fan shuts off. When you got to your destination the bike cooled down, no need for the fan to come on, charging was fine. JMO
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 11 (permalink) Old 06-30-2012, 06:14 PM
ifixf18s's Avatar
Is everything original on the bike? From what ive read on here the charging/electrical system on this bike is a bit weak. When you test the charging system with a meter your suppose to bring up the RPM's to about
4K.
ifixf18s is offline
post #7 of 11 (permalink) Old 07-01-2012, 06:07 PM
Chuck A.'s Avatar
Hey its all good. Charging system takes a few seconds in the 2000+ rpms when its good and hot. You should be in range with all the vn 750s out there. You just don't know all this is you don't have a light, meter, or guage.
Chuck A. is offline
post #8 of 11 (permalink) Old 07-01-2012, 08:32 PM Thread Starter
I didn't consider this....I think you're right. Today....90+ degrees, 2 Up, 1 hour...same thing.
Curiosity solved.
Thanks all!
VoIPDoc is offline
post #9 of 11 (permalink) Old 07-03-2012, 02:30 PM
first question I have, Where is your voltage indicator plugged in at, is it wired via a relay strait to the battery? If it is hooked up like many people do to the Brown wire, you aren't getting an accurate reading when the fan comes on. second have you put a multimeter on the bike at idle with the engine warm. The Windings of the stator might be going bad, hence a hot check and cold check in my flow chart. It sounds like you have a couple things going on, first your volt gauge is hooked up wrong, second your stator isn't putting out 12.5+ at idle when hot due to deteriorating windings or a week rotor, and third the combination of both. Test the Stator VAC output when the bike is hot and fan running at idle, 1500 rpm, 2500 rpm, 3500 rpm, and 4500-5000 rpm. At idle you should be seeing around 60 VAC, any thing less and the stator is shot, and at 4500-5000 rpm you should be near 80 VAC,
post #10 of 11 (permalink) Old 07-03-2012, 02:41 PM
I would expect 20-30 at idle, not 60
