Fuse box - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 06-30-2012, 10:15 AM Thread Starter
Kawhampshire's Avatar
Fuse box
Has anyone had to replace the fuse box? I found mine is causing alot of concerns. I took it out and drilled out the back rivits and found overheated and corroded connections on the board inside. See the photo below. Does anyone have an extra?
Name:	Fuse panel.jpg
Kawhampshire is offline
post #2 of 2 (permalink) Old 06-30-2012, 01:43 PM
Let's Ride!!
DaveT319's Avatar
First off, I've had problems with mine before. The headlight relay stopped working. I managed to get it open (with some help) and replace the relay. Worked fine ever since.
Second, I have a spare one from a 2005 parts bike that had under 20k miles on it. Should work just fine (have not tested it though). PM me if you're interested, I'll let you know a price.
DaveT319 is offline
