Headlight inop - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-29-2012, 07:53 PM Thread Starter
Senior master
Question Headlight inop
Ive got an 86' vn750 and since I got it the head light is inop. I've put a new bulb and the fuses check out. All the connectors are good. I haven't checked power and ground yet but want to see what y'all had for input for me. I would greatly appreciate it thanks.
Mastertech80 is offline
post #2 of 10 (permalink) Old 06-29-2012, 08:42 PM
Calif Rider
weh44att's Avatar
You definatly need to check for power and the ground before you do anything else. Do the easiest things first. Also you need to check your wires in the headlight housing to see if they are in good shape. The bike is old and wires start to chafe and ground out.
If everything looks okey and you have power there or other things to check. Get back on the sight and let us know what you found. There other wires that could be checked or electrical items that can cause the light not to work.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 10 (permalink) Old 06-29-2012, 08:49 PM
fuse checks out good, and bulb checks out good.. number one cause is a bad headlight relay.. the relay is inside the junction box. fix??? take the blue wire from the junction box and move it to the unused pin of the junction box.
post #4 of 10 (permalink) Old 06-29-2012, 09:57 PM Thread Starter
Senior master
Can I still upfit extra lighting on that wire or do I need to go a different route?
post #5 of 10 (permalink) Old 06-29-2012, 10:29 PM
no... even if the headlight worked normal that is not a good idea.. the wire is barely rated for the headlight, let alone more maps drawn from more lights.
post #6 of 10 (permalink) Old 06-29-2012, 10:42 PM Thread Starter
Senior master
So how would I go around putting on extra lighting ?
post #7 of 10 (permalink) Old 06-30-2012, 12:41 AM
Tape a couple flashlights to your head? Seriously, the power output of the stator doesn't give much room for lights. Unless you plan to use LED's all the way around, I wouldn't worry to much about adding extra lights. The stock light does a good job on its own. I had a Honda 1300C and its headlight sucked. I couldn't run hi-beam due to the way it reflected the light. I saw less on hi-beams than low-beams with that bike. I see even more on the VN750 than I ever could with the 1300C.
Might consider getting a brighter bulb, like a SilverStar bulb.
Good luck.
post #8 of 10 (permalink) Old 06-30-2012, 01:06 PM Thread Starter
Senior master
Sorry I meant as far as running led frame and engine red lighting.
post #9 of 10 (permalink) Old 06-30-2012, 01:51 PM
Let's Ride!!
DaveT319's Avatar
There's a couple of accessory wires in the headlight bucket. They will stand out because they are the only two wires not connected to anything, and should have big rubber covers on the ends. Connect the frame and engine lights to those.
DaveT319 is offline
post #10 of 10 (permalink) Old 07-05-2012, 02:08 PM Thread Starter
Senior master
Thanks for the huge help. I relocated the wire and it works like new. On too of the new 900 seat it really is comming along.
