headlight doesnt always come on when starting bike?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-24-2012, 06:51 PM Thread Starter
Hi all,
I've started having an intermittent (gasp) problem I'm hoping you can help with. Lately when I start my 99 Vulcan the headlight wont always come on. If it does, it stays on for the entire time the bike is running. However, when it doesn't, I cant seem to get it to come on for anything. Is there a relay somewhere that is supposed to close when the starter is no longer engaged?
Vulcanian is offline
post #2 of 5 (permalink) Old 06-24-2012, 07:15 PM
Yes, the relay is soldered into the fuse box. it is activated by a wire from the voltage regulator. usually this said relay not closing attributes to charging issues or week connections on the stator leg wires.
post #3 of 5 (permalink) Old 06-25-2012, 07:59 PM
mine had issue with light, moved blue wire to unused spot in plug for fuse box bypassing relay have not had any issue with it since
vulcan98 is offline
post #4 of 5 (permalink) Old 06-25-2012, 08:26 PM
X2 ! Clean your Ignitor Box and Fuse box connectors, which should resolve the problem.
Hope this Helps
Williamtech
post #5 of 5 (permalink) Old 07-15-2012, 07:40 PM Thread Starter
UPDATE: It was a bad headlight relay. I changed the blue wire over to unused terminal on the junction box and it works every time now. Thanks all!
