Help- No Power - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 08-16-2006, 05:14 PM Thread Starter
Help- No Power
Something odd just happened. Was testing out my cooling fan switch, and also the temp gauge. Both worked good. After hooking up the wires. Went to start bike, it clicked and sounded like a blown fuse. Checked fuses, all good, even replaced them to be safe. Still now power at all. Going to borrow a multimeter and check the voltage in the junction box. Did notice one think, the flasher relay behind the battery is in pretty rough shape, unplugged and tried, but still no power.
Pulling my hair out here, anyone know what I did wrong?
Started with cooling gauge not working, it was intermittent then stopped. Then fan also quit turning on at stoplights, yesterday was hot and never turned on once.
Help.......
photohap is offline
post #2 of 18 (permalink) Old 08-16-2006, 05:21 PM
Uber Member
check the plugs going into all compnets....corrosion grow rapily there.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 18 (permalink) Old 08-16-2006, 05:48 PM Thread Starter
I think I found the culprit. Behind the battery on the left side top, there is black and yellow wire with a factory splice on it. When I wiggled the wire, power came back on but not enough juice to start, cut the splice out and respliced it with household splice till I can get a bullet splice from the store and starts up now. Still no coolant gauge though, unsure about the fan, will find out after I take it for a ride.
photohap is offline
post #4 of 18 (permalink) Old 08-16-2006, 07:16 PM
Once Banned
cegodsey's Avatar
That's the same wire that drove InsuredDisaster to the brink. It's the ground wire for everything on the bike.
To find out if the fan itself is shot, disconnect the fan switch at the bottom left side of the radiator, and touch the wire to a bolt on the frame (ground). If the fan starts, then the fan is OK.
The fan and the coolant gauge or not connected. The coolant gauge hooks to a temp sensor at the thermostat.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #5 of 18 (permalink) Old 08-16-2006, 09:44 PM
Sky Rider's Avatar
Another test for the fan motor is to hook it up to a separate 12v power source. Mine won't run if I just ground it against the frame because the relay in the junction box is blown. At least I know the fan motor is good. I'm going to bypass the relay and make it a manual switch so I can control when it comes on.
I haven't needed it yet even in our 96 degree plus weather down here as I ride on freeway type roads.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #6 of 18 (permalink) Old 08-16-2006, 09:50 PM Thread Starter
This bike is Possessed!!!!
Well after fixing the wire, took it for a ride. Was doing about 50, then wham!! it felt like I was starving for gas, I knew that feeling to well since I had it once before (before I cleaned the carbs). The bike died right in front of an AutoZone (how conveniant for me). So I went inside, bought some seafoam, and some gumout. Cleaned out the drain bowls with the gumout a few times, did the on and off trick with the gas tank. It still ran like crud, finally was able to barely run it around their parking lot, and decided to limp it on the 2 mile journey home.
Lo and behold after a half mile of driving, the bike ran perfect, the fan even kicked on at a stop light.
Is this bike possessed or what?????
I am praying I don't have to pull the carbs again, but if I do I am going to do the ear shave most likely so they will be easier to get in this time...
Oh the coolant sensor is shot, I checked it out earlier, fan is good, just wasn't get hot enough to turn on.
photohap is offline
post #7 of 18 (permalink) Old 08-16-2006, 10:39 PM
HAWK
Ccspinner's Avatar
The gremlins jumped off at Auto Zone, Good luck for you.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 18 (permalink) Old 08-16-2006, 10:47 PM
hgree's Avatar
Where's that ride bell when you need it?
Out of VN750s...
On to bigger and better things!
1997 Black & Silver ***SOLD***
Insurance Replaced: 08/25/2008
Mileage: 10/29/08- 4644 miles
Son's **Sold: In the ARMY & married $$$**
1995 Teal Green
Purch 08/17/2007: 14,240 miles
10/29/2008: 17,640 miles
Wife's **Sold: shoulder injury**
1999 Gray/Black w/Fairing
Purch 06/22/08: 18,160 miles
10/29/2008: 19,889 miles
hgree is offline
post #9 of 18 (permalink) Old 08-16-2006, 11:06 PM
Once Banned
cegodsey's Avatar
If you continue to have problems, you might check for a faulty ground.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #10 of 18 (permalink) Old 08-16-2006, 11:50 PM Thread Starter
Gremlins it must be
Gremlins it must be. I just rode a 2 mile straight away back and forth 5 times to let the sea foam work in. The bike road much better, still has a slight hicup when punching it , but nothing like earlier.
Pulled and cleaned the plugs and will run it tomorrow to see the results.
photohap is offline
