Low voltage while running. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 06-21-2012, 03:53 PM Thread Starter
Madmaverick83
I am new so please dont yell to much because i am sure this is somewhere in here just didnt see it, yet. Any how i have been having a problem with my bike shutting off while idling when i hit the breaks. Looked around heard that its prone to weak electrical and to replace lights with leds. So i replaced my break lights with led replacements and replaced head light with HID both because they draw less power. once i have done this it runs fine now no problem. I have however noticed that the battery seems week, it had a warranty so i swapped it out. better but still seems to not crank over as fast as it should unless i keep it on a battery tender. So i finally checked the voltage at the pig tails for the battery tender while running. about 12.6v before start, 11.95v after start, reved to 3000 rpms got 12.11v, took it for a hour and a half ride came back. as i was letting it run and getting my multi meter again the cooling fan came on a killed the engine. started it back up with a little problem but not too bad. Checked it while running this time it was at 11.4 v reved again to get 11.5v. now my multi meter may not be the most accurate thing in the world but i know its close enough. So WTF is going on? is it a voltage regulator or the (and i sure hope its not) stator? or something else?
madmaverick83 is offline
post #2 of 25 (permalink) Old 06-21-2012, 04:04 PM
#1: Check all connections. A faulty ground can cause havoc.
#2: Slim posted a guide on how to test the R/R and stator separately with your meter. Run through those tests and they should identify the culprit. Could be stator, but without the tests you can't rule out the R/R.
post #3 of 25 (permalink) Old 06-21-2012, 04:37 PM Thread Starter
Madmaverick83
where would i find his guide at?
post #4 of 25 (permalink) Old 06-21-2012, 05:43 PM
JM2001's Avatar
I can't find Slim's guide but read this thread.
https://www.vn750.com/forum/showthrea...ht=stator+test
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 25 (permalink) Old 06-21-2012, 05:48 PM
my Flow Chart .. just fallow the link in the thread... do EVERY single test that I have listed.. weather you feel its pertinent or not.. then post those numbers back in this thread. From there we can pinpoint exactly what is going on.
post #6 of 25 (permalink) Old 06-21-2012, 05:48 PM
ifixf18s's Avatar
Here ya go, (edit) looks like Slim beat me to it
https://www.vn750.com/forum/showthread.php?t=21206
ifixf18s is offline
post #7 of 25 (permalink) Old 06-21-2012, 08:05 PM Thread Starter
Madmaverick83
ok, i will get started on it but have too cook dinner too. will see how much i can get done today.
post #8 of 25 (permalink) Old 06-21-2012, 08:26 PM
Check your big batt cables first. Espacially the ground.
post #9 of 25 (permalink) Old 06-21-2012, 08:28 PM Thread Starter
Madmaverick83
well this is interesting. so i took my seat off and the side cover and find that one of my stator wires was not connected. No idea how but it wasnt, any way i fired it up to get some readings for you to see what you think. 12.65v prior to start, 12.05 at cold idle with head light off (previous owner put it on a switch), 12.45v at 2500 rpms, 11.85v at idle with headlight on but at 2500rpms went to 12.4 and looked to be increasing. didnt take readings for long because i didnt want to warm the engine up because flow chart said to have engine cold. whats your take on it. it took only a minute or two of run time while performing these checks
post #10 of 25 (permalink) Old 06-21-2012, 08:49 PM
Rev up to 4K and see if you get up to high 13v or low 14v.
