Volt meter connection? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-19-2012, 02:38 PM Thread Starter
MrSkydriver
MrSkydriver's Avatar
I have installed a volt meter that I need to connect to an ignition wire so it is not on all the time. I used the plugs in the headlight for the + and - but the third wire goes to an ignition wire (so it is on only when the ignition is on). Can one of you electrical geniuses tell me which wire to connect to in the headlight?
Name:	Volt meter.jpg
2006 Vulcan 750
NGK Iridium DPR7EIX-9
AGM Interstate CycleTron II
Saddle Bags
Natl. Cycle Deflector Screen
SilverStar Headlight 9003/H2 H4
Ext. Back Rest
R/R relocation
Digital Volt Meter 5 IN 1
Engine Guard w/pegs
ProTac Back Rest
Trunk (not installed)
Pickup coil mod
Metzler ME 880 Marathon
front: 110/90 - 19 rear: 170/80 - 15
Kury grips
Hopefull:
Nice Lady on the back...
MrSkydriver is offline
post #2 of 9 (permalink) Old 06-19-2012, 02:49 PM
I can't answer your question. But I am curious where you got that thing....
Old Bike: 2006 VN750 - Sold
eusjma is offline
post #3 of 9 (permalink) Old 06-19-2012, 03:25 PM
The marker lights from the front blinkers run into the headlight bucket. You can tap into those. you can also use the back lighting for the dash.
marker lights and dash lights should be R/BL
post #4 of 9 (permalink) Old 06-19-2012, 03:37 PM Thread Starter
MrSkydriver
Volt meter
eusjma,
here is the link for the volt meter.
http://www.bigbikeparts.com/Inventor...-239?catalogNo
Where are you in the Dallas area? I moved to Nor Cal from Dallas.
Gregg
2006 Vulcan 750
Saddle Bags
Ext. Back Rest
R/R relocation
Engine Guard w/pegs
ProTac Back Rest
Pickup coil mod
Kury grips
Hopefull:
post #5 of 9 (permalink) Old 06-19-2012, 03:41 PM
romeobravo172
romeobravo172's Avatar
Super easy to trace that running light wire inside bucket! You can also install an on-off switch to the meter. I chose to go that route simply because I felt no need to it being on all the time while riding,plus just sitting in garage I can ck batt stat without the key being turned on. Just another idea!
romeobravo172 is offline
post #6 of 9 (permalink) Old 06-19-2012, 05:24 PM
Originally Posted by MrSkydriver View Post
eusjma,
Gregg
I live in Allen (near Plano, Richardson...). What part are you in?
eusjma is offline
post #7 of 9 (permalink) Old 06-19-2012, 06:18 PM Thread Starter
MrSkydriver
I'm in Santa Rosa, CA (wine country - 50 miles n. of SF). I lived in Richardson, TX at one time. Dallas, Waco, Austin, Houston, Longview, Tyler, Galveston, etc. too.
Gregg
2006 Vulcan 750
Saddle Bags
Ext. Back Rest
R/R relocation
Engine Guard w/pegs
ProTac Back Rest
Pickup coil mod
Kury grips
Hopefull:
post #8 of 9 (permalink) Old 06-19-2012, 06:40 PM
Cheman's Avatar
I have that same meter on my VTX1300. I have it wired to always be on. The draw is so small, your bike would have to sit for weeks and weeks to drain the battery. I can walk past the bike and check the voltage, temp, time.
Of course my VTX has not shown any sign of a charging problem(knock wood)
Che
1986
Purchased 7/03 w/13000 mi
Sold10/10 27,000miles
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
Clear Alternative LED brake light
TOC mcct
Mutazu LN Hard saddlebags
Chad's floorboards
Current ride-2009 Honda VTX1300
Cheman is offline
post #9 of 9 (permalink) Old 06-19-2012, 07:15 PM
Cheman's Avatar
Just thought a bit more about this. Its been a while since I installed it, but the wire you are talking about is probably just for the backlight on the meter. Don't really remember.
But mine is on all the time but the backlight is only on when the bike is on, so that would make sense..
Che (with the foggy brain)
1986
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
TOC mcct
Chad's floorboards
Cheman is offline
