Starter Or R/R - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 06-15-2012, 07:50 PM Thread Starter
Unhappy Starter Or R/R
Hi All,
I recently purchased a 1987 Vulcan 750, owner said the battery was dead. It would run for 1 week and the battery would go dead. So I figured I'd purchase a new battery. The bike still has the same issue, it runs for about a week and then the battery goes dead. After doing someone research, I purchased a voltage regulator. I checked the voltage at battery terminal and it read 12.35. I brought the RPM's up to 4k and it read 13.75. Any feedback or suggestions? Is 13.75 sufficient?
JK5150 is offline
post #2 of 21 (permalink) Old 06-15-2012, 08:38 PM
under 14 at 4000 RPM is week.. and 14.5 at 4000 is even better. Test the stator VAC and Short to ground on all three legs. Also what kind of battery did you buy?
post #3 of 21 (permalink) Old 06-15-2012, 08:59 PM Thread Starter
stator vac how would you check that?
JK5150 is offline
post #4 of 21 (permalink) Old 06-16-2012, 08:42 AM
set the multimeter to Volts AC, its the the squiggly line.
post #5 of 21 (permalink) Old 06-16-2012, 09:26 AM Thread Starter
Thank going to check
JK5150 is offline
post #6 of 21 (permalink) Old 06-16-2012, 01:25 PM Thread Starter
AC at idle 19 to 20 all 3 wires
AC at 4000 rpm 54 all 3 wires
JK5150 is offline
post #7 of 21 (permalink) Old 06-16-2012, 02:03 PM
Idle sounds decent, but 54 is a bit low. It sounds like the stator is working it's way out. You really want to see around 70 or so.
post #8 of 21 (permalink) Old 06-16-2012, 02:55 PM Thread Starter
That sucks the dealer for kawasaki will not service the bike
JK5150 is offline
post #9 of 21 (permalink) Old 06-16-2012, 03:38 PM
Find an independant shop, or do the work yourself. either way you want to use a Tim Parrot Rewound stator from TPE... http://www.tpe-usa.com/
post #10 of 21 (permalink) Old 06-16-2012, 06:45 PM Thread Starter
Hard to find motorcycle repair shops around here in Newfoundland only dealers that only want easy jobs. I have to give it a go
JK5150 is offline
