Spark Plug Suggestions Anyone? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 06-15-2012, 12:40 PM Thread Starter
I'm going to pick up some spark plugs for my 86' vn750 today and was wondering if anyone had any brand/type suggestions along with their part # so i can just head to autozone and pick up a set.
Thanks! and happy Friday!
BikerDad81 is offline
post #2 of 24 (permalink) Old 06-15-2012, 12:58 PM
NGK iridium DPR7EIX-9
costly but the best, and they are pregapped so you can just install and ride,
Swagman is offline
post #3 of 24 (permalink) Old 06-15-2012, 01:14 PM
JM2001's Avatar
X2, $6.99 ea. at Advance Auto but worth it.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 24 (permalink) Old 06-15-2012, 01:17 PM
X2 with Swagman ! Better - Easier starts and great/improved performance ! Be aware, you will need to remove the little end caps from your new plugs.
Enjoy
WilliamTech
post #5 of 24 (permalink) Old 06-15-2012, 01:19 PM
Gemguy's Avatar
Besides the improved performance, they are good for 40 to 50,000 miles. Have a set now for 2 years and love em
~VROC~ # 389
Gemguy is offline
post #6 of 24 (permalink) Old 06-15-2012, 01:26 PM
MrSkydriver
MrSkydriver's Avatar
Just a reminder, it takes 4 spark plugs....iridium=great
2006 Vulcan 750
NGK Iridium DPR7EIX-9
AGM Interstate CycleTron II
Saddle Bags
Natl. Cycle Deflector Screen
SilverStar Headlight 9003/H2 H4
Ext. Back Rest
R/R relocation
Digital Volt Meter 5 IN 1
Engine Guard w/pegs
ProTac Back Rest
Trunk (not installed)
Pickup coil mod
Metzler ME 880 Marathon
front: 110/90 - 19 rear: 170/80 - 15
Kury grips
Hopefull:
Nice Lady on the back...
MrSkydriver is offline
post #7 of 24 (permalink) Old 06-15-2012, 01:35 PM
We all know I'm a total dork right? Good. Iridium trivia: anyone know where iridium came from? It's not indigenous to our planet. A gargantuan iridium meteor crashed here 65 million years ago and kicked up enough red dust into our atmoshspere to block out the sun. No sun - no plants, no plants - no herbivores, no herbivores - no carnivores. Iridium ended the dinosaurs...now its in our spark plugs. LOL!!! That explains why it's so expensive - VERY limited supply...
LibertyPilot is offline
post #8 of 24 (permalink) Old 06-15-2012, 01:41 PM
Drive less, ride more...
theauhawk's Avatar
Be sure to pick up and use some spark plug anti-seize compound--& apply this to your new spark plug threads b4 screwing them in.
It's also a good idea to use some compressed air to blow out the spark plug recesses in the cylinder heads, before removing the plugs. Sometimes, you'd be surprised at what is waiting in there to make a new home inside your engine!
Also--there's a special socket that came with your bike's tool kit, that fits the taper of the spark plug locations, specifically for removing and installing spark plugs. This will be easier for you to use than a regular spark plug socket. If you use a regular spark plug socket, you may have to machine it some to get it to fit in the recesses properly.
Iridium plugs require less juice to fire (& so less work for your bike's ingitors), and stay clean/gapped A LOT longer than regular plugs. That's why they're worth the extra money, as recommended above.
All this should make your spark plug swap A LOT easier.
'05 VN750
theauhawk is offline
post #9 of 24 (permalink) Old 06-15-2012, 02:29 PM
I don't know where you got that idea about the iridium on earth coming from a asteroid. Not true. Some iridium came that way, but certainly not all. Better check your facts again. Of course you could claim everything on earth came from someplace else and be technically correct. You know there is something that has always bothered me about the asteroid killing all the Dino's theory. If they all died around the same time, why airnt there massive piles of bOnes at the K-T boundary ?
dariv is offline
post #10 of 24 (permalink) Old 06-15-2012, 03:21 PM Thread Starter
Thanks for all the suggestions and tips! I'm going to go with the Iridium plugs i think, Lots of good feedback
