Race Tech Stator - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-12-2012, 03:03 PM Thread Starter
Crap, I WAS in 5th gear.
Race Tech Stator
Ok guys, I took one for the team, and thought I would try a Race Tech stator while waiting for my core to be rewound at TPS. I got the stator off of Ebay and it was delivered to me the day after!
Voltage at idle is 12.4. Since I cut the old one out of the case and made an adaptor plate, I was wondering how much centering affects output voltage? I believe I am centered pretty well axially, but perhaps the core isn't extending far enough in? Is the stator self-aligning for depth, and then you shim out any difference?
Oh, I am due for a new battery, but that really shouldn't affect the bus voltage, but perhaps it does. I know it needs some water, so I'll try that first while I'm waiting for my AGM.
I need to pull it apart anyway to fix the grommet hole that I cut oversized.
Kelly2001 is offline
post #2 of 11 (permalink) Old 06-12-2012, 03:14 PM
The best test would be to unhook the 3 leads from the stator and test the AC voltage between them. You want over 20 at idle, and upwards to 70+ at 5k rpm
post #3 of 11 (permalink) Old 06-12-2012, 03:22 PM Thread Starter
24 VAC at idle, from what I remember haven't checked at 5K. I think my R/R is ok. My new 20A spare RR is not as efficient, and delivers 12.3V. Now I will have a spare rotor and R/R!
post #4 of 11 (permalink) Old 06-12-2012, 03:52 PM
Not bad idle voltage, My TPE stator is pushing 35v or so at idle.
I was running a stock style R/R off a ninja 600 that was pushing 14.9 at idle, and 14.3 at 5k. I swapped it to a mosfet and am getting 14.6 everywhere.
If you have the budget for it, check out the MOSFETs. They're awesome. At idle, if i hit my brake light, it dips to 14.5, and climbs back to 14.6. Quality regulation there. :P
post #5 of 11 (permalink) Old 06-12-2012, 04:00 PM Thread Starter
I was looking at MOSFETs, but the Shindingen isn't made anymore, from what I can tell. Can you recommend one? I don't mind re-wiring.
post #6 of 11 (permalink) Old 06-12-2012, 04:38 PM
I was tol that the 2003 yamaha r1 is a good swap for our bikes. have not done this yet due to I need to do the stator mod myself.
TheEDGE is offline
post #7 of 11 (permalink) Old 06-12-2012, 04:48 PM
romeobravo172
romeobravo172's Avatar
Don't know about the stator but the red lenses to replace the amber ones is a perfect match--RTSL1300---
romeobravo172 is offline
post #8 of 11 (permalink) Old 06-12-2012, 07:07 PM
yes the 2003 R1 is a Shidegen 012AA R/R...
post #9 of 11 (permalink) Old 06-14-2012, 02:48 PM Thread Starter
Topped up my battery and fully charged it. I'm getting 12.43V DC at idle, and 12.18V idling with the cooling fan on. Any of you guys measured voltage with your fan on?
post #10 of 11 (permalink) Old 06-14-2012, 02:54 PM
With the stock R/R and a TPE stator I was getting 14.9, and 14.6 with fan on.
With the mosfet I get 14.6v no matter what. I used a different mosfet off a ZX-14. Ebay search
