Spark plug wire: where to get? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-10-2012, 07:11 PM Thread Starter
Let's Ride!!
DaveT319's Avatar
I've seen others get colored spark plug wires to kind of match their paint job. So I think I might like to do that too. Where do I get it?
DaveT319 is offline
post #2 of 7 (permalink) Old 06-10-2012, 07:32 PM
JM2001's Avatar
They have pages of them here
https://www.denniskirk.com/search/sp....q/20.ipp/3.pg
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 7 (permalink) Old 06-10-2012, 07:33 PM
Full sets for our bikes with good NGK caps, totaling $42.34 shipped.
- Red
- Yellow
- Black
post #4 of 7 (permalink) Old 06-11-2012, 02:17 AM Thread Starter
Let's Ride!!
DaveT319's Avatar
Ooo, somehow I didn't think they'd be that much. I'll probably have to wait on those then.
DaveT319 is offline
post #5 of 7 (permalink) Old 06-19-2012, 08:26 PM
Bat
Bat
Bat's Avatar
I thought I would like bright yellow sparkplug wires to brighten up the old gal a bit and match my general riding gear, so got a set from NGK, they got here yesterday and are beautiful. I haven't looked at the bike yet, but see that the coil end of the new wires is just cut off, no connector. I suppose I'll figure it out, but thought you might care to give some input on how to best connect the cut end to the coil. Thanks.
Bat
Bat is offline
post #6 of 7 (permalink) Old 06-20-2012, 09:14 AM
Use the ends from the old set. If I remember right, you slide the end up the wire and remove the little o ring first and then take the end off.
4/12/12 1st bike ever! 95 VN 750 13k
New plug wires
Iridiums
Coil relay mod
MCCT mod
EPA stuff removed
Rear signals shaved
Shinko 170-110 oversized tourmaster tires
Splines lubed
Front signals relocated.
skyboxer is offline
post #7 of 7 (permalink) Old 06-21-2012, 02:05 AM
Bat
Bat
Bat's Avatar
Ah So...many thanks, Skyboxer!
Bat is offline
