Reminder: Use Loctite on the stator screws! :( - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-10-2012, 02:03 AM Thread Starter
I had planned a nice 100 mile ride today, since my MOSFET install went so well last night. I was cleaning up the bike, making it presentable, and was going to test the charging prior to heading out (just in-case). I start up the ride, all good, until I detect a tapping at the outer stator cover.
I grabbed a screwdriver quickly to locate the origin of the noise, and sure enough, loud as hell from the stator cover. I kill the throttle instantly, and sigh heavily. I had spent my budget set aside for biking this check, so I can't get any gasket maker until next week.
I am going to open her up and check it out tomorrow, and hope it was just one of the outer cover screws that backed out against the outer cover. I swear I put loctite on each one prior, but I guess I could have missed one. Really killed my weekend, what a bummer.
Moral of the story is to make sure to use blue loctite on the stator screws. Don't ruin your beautiful weekend that you had set aside to ride like I did! I've spent more time wrenching than riding lately, and that's not a good ratio.
post #2 of 12 (permalink) Old 06-10-2012, 01:59 PM
Did you set the pickups to close to the rotor or have they slipped and are catching the magnet???
Swagman is offline
post #3 of 12 (permalink) Old 06-10-2012, 02:35 PM Thread Starter
I'll know in a few hours. The pickups were on securely and were not modified so they should not really move.
I was going to check it out this morning but work happened unexpectedly.
post #4 of 12 (permalink) Old 06-10-2012, 04:32 PM
Work has a habit of doing just that, hope its something simple and easily sorted
Swagman is offline
post #5 of 12 (permalink) Old 06-10-2012, 07:01 PM Thread Starter
All fixed and back together in 1 hour 30 minutes from start. Not bad. That means I can swap a stator in under 2 hours.. sweet! Most of that time was spent cleaning the gasket as per usual.
It was an inner stator screw that backed out, and was about to be free-floating in the rotor! Luckily my Vulcan ears treated me well, and I detected the noise prior to my long trip. A liberal amount of blue loctite has been applied, and am I letting it set for a bit prior to starting her up and taking a cruise.
The moral of the story is always double check your screws. I put some loctite on the pickup screws as well.
post #6 of 12 (permalink) Old 06-10-2012, 08:09 PM
You removed the engine and replaced it in 1 and 1/2 hours? If so that is really good.
post #7 of 12 (permalink) Old 06-10-2012, 10:30 PM Thread Starter
I wish. I have the tuxedo mod done, so it was just the side-cover.
Back from a beautiful 42 mile ride along the coast. Loving it!
post #8 of 12 (permalink) Old 06-11-2012, 09:31 AM
Thats great news so pleased it was a simple fix for you, now hopefully you can enjoy the rest of the season.
Swagman is offline
post #9 of 12 (permalink) Old 06-11-2012, 11:14 AM
Captive New Yorker....
peterherrm's Avatar
Are you talking about one of the screws that holds the stator to the inner cover came lose??
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #10 of 12 (permalink) Old 06-11-2012, 12:21 PM Thread Starter
Correct
