MOSFET R/R Installation Pictures & Notes - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
LinkBack Thread Tools
Old 07-10-2014, 04:48 PM
OldHipWesTex's Avatar
Send a message via Yahoo to OldHipWesTex
Yeppers, a hand dandy job i must say! Looks nice.
Vulcan #1 1993 - 28K
Vulcan #2 1999 - 26k
It All Comes Down To 3 Things:
#1 Fuel
#2 Spark
#3 Mechanical
Any One Fails - Then It Dont Run
____________________________________
ANTICIPATED MODS:
Build Fiberglass Fenders F/R
Mold & Cast New Turn Signals Lights
OldHipWesTex is offline
Old 07-30-2014, 08:18 PM
Memphis's Avatar
Originally Posted by thtanner View Post
Thanks Slim.
Some notes to add to the fray for anyone following MOSFET stuff.
Model / Output / Source Bike
FH001 / 35A / FJR 1300
FH008EB / 40A / BR 600 RR
FH010BA / 50A / ZX-10R
FH012AA / 50A / FJR 1300, R1
FH012BA / 50A / ZX-14R, ZR1400, GTR1400
FH014AA / 50A / CBR 1000 RR
FH016AA / 40A / ZX-6R
Our regular R/R is under or at 30amp anyways, so any of the MOSFET based R/Rs look to be an upgrade. I see no reason to shoot for a FH012AA, as the FH010BA (the one I used), and many others, are also 50A. I'd cross reference the bikes years, but that's the basic list.
So I see a lot of different options on Ebay for new R/R and I am curious of all the bikes in this list. Do any of them plug straight up or do they all require you to do some custom wiring? If they do require custom wiring how do you get the wiring to plug up to the different R/R?
Memphis is offline
Old 07-30-2014, 09:05 PM
If it's a true MOSFET r/r then you need a wiring harness. You can get them from roadstercycle.com
Old 07-30-2014, 10:25 PM
Memphis's Avatar
Ahh great, thank you!
Memphis is offline
Old 03-17-2015, 04:34 PM
InvisiBill's Avatar
Originally Posted by sgorveatt View Post
Originally Posted by yevgenievich View Post
there is a brown wire in the output of the regulator. Do you connect it back with a new regulator?
I don't like to do this, but I would like to bump this question. I have the exact same question. If using the stock wiring harness, what does the brown wire on the original R/R do? Can you you just skip it and if so why?
The old R/R uses the brown wire (the source of basically all switched power on the bike) to get feedback on the system's voltage. The new R/R's use the main + wire for this rather than having a separate wire.
Just ignore the brown wire with a new R/R. It's carrying 12V when the ignition is switched on, so make sure it can't short out to anything else. Leave that pin unconnected if you're adapting the new R/R to the stock plug, cap off the bare wire if you're installing different connectors, or completely remove that fork of the brown wire if you're cleaning up your harness.
1985 VN700 A1 (Sold) | 2009 Ninja 500R EX500D9F
VROC #32761
InvisiBill is offline
Old 03-17-2015, 04:49 PM
InvisiBill's Avatar
The ZX6R's FH016 may be a great option for the VN750.
Random internet image of FH016 kit
It has wire pigtails rather than the expensive Furukawa connectors, so you can cut off the weird Kawasaki plugs and put whatever connectors you want on it (this one has Metri-Pack connectors installed already).
Instead of just having the + and - wires (black/blue and black/white) in the second plug, it has a third wire (black) tied into one of the three stator wires. If you're completely bypassing the stator wires in the OEM harness, this provides an easy way to get the stator signal (yellow wire) to the junction box for the headlight turn-on.
Also, http://www.cycleterminal.com/ sells the Furukawa connectors and stock R/R connectors (along with a bunch of other electrical stuff). The prices are about the same, but the minimum order is lower than EB since he's not shipping from Japan.
VROC #32761
Old 05-08-2018, 04:56 PM
vulkan's Avatar
$139 for the Regulator (Rectifier...??) and $144 for Ricks stator...lookin at $280 buckaroos.
vulkan is offline
