MOSFET R/R Installation Pictures & Notes - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 27 (permalink) Old 09-13-2012, 05:54 PM
post #12 of 27 (permalink) Old 04-28-2013, 10:49 PM
Fh020aa
I was thinking about getting this R/R http://www.ebay.ca/itm/380473041443?...84.m1423.l2649
Would this have all the connections I need, and is it a bit overkill?
Also what are people's opinion on fusing the three wires coming from the stator? Is there a consensus or are people still of differing opinions?
sgorveatt is offline
post #13 of 27 (permalink) Old 04-28-2013, 11:18 PM
Lightbulb
That's the same kit I'm putting on, but from a different seller. This is the same one from Roadstercycle, he's a good person to work with if there's any problem, very helpful. Looks like the shipping has gone up, but I think you might get a better price at his website:
http://www.ebay.ca/itm/FH020AA-Shind...item3f219eeec4
Roadstercycle website:
http://roadstercycle.com/
I don't think it's overkill, you get plenty of battery wire, fuse for charge circuit, and just enough fittings. I had to round up some larger gauge stator wires.
The MOSFET is supposed to handle and bleed off the extra current better, without getting as hot.
The consensus I saw on stator fuses was that it wasn't really worth it. I'd still want a voltmeter to let me know I might have blown a fuse.
I found some small, cheap, digital ac voltmeters and thought about three of those to watch the stator voltage. Maybe hide them behind side cover or under the seat. I pretty much forgot about it though.
post #14 of 27 (permalink) Old 04-30-2013, 02:14 PM
there is a brown wire in the output of the regulator. Do you connect it back with a new regulator?
92 Stealth
89 Trans Am
67 Camaro
91 suburban v2500
yevgenievich is offline
post #15 of 27 (permalink) Old 05-07-2013, 11:40 PM
I don't like to do this, but I would like to bump this question. I have the exact same question. If using the stock wiring harness, what does the brown wire on the original R/R do? Can you you just skip it and if so why?
Thanks
post #16 of 27 (permalink) Old 05-08-2013, 12:33 AM
Well, according to this link, it goes to a junction point where it branches to junction box and ignition switch.
post #17 of 27 (permalink) Old 05-28-2013, 05:35 PM
Can anyone verify which pin the yellow stator wire jumpers to at the Junction Box?
Looks like it belongs, as it's plugged into the JB, on the lower plug, back row, second hole from the bottom?
I disconnected this one over a month ago and I have two empty pins on the lower plug. Besides trying the headlight bypass and now forgetting which mode I left it in.
post #18 of 27 (permalink) Old 05-28-2013, 07:04 PM
If you did the head light bypass then you don't need to figure out where the yellow write from the stator goes. The yellow write only triggers the headlight relay inside the jb.
The brown wire senses the load so that the stock rr can correctly regulate the voltage. The mosfet regulator doesn't need this function.
post #19 of 27 (permalink) Old 05-28-2013, 07:39 PM
Just not sure which mode I left the bypass in. If the headlight works when I get it together, I'll do away with the yellow jumper so I get the voltage benefit. If not, I'll do the bypass again. Guess I coulda thought of that earlier huh.
post #20 of 27 (permalink) Old 09-23-2013, 06:16 PM
just got mine from mntsnow along with a stator to go to todd to be rewired. holy crap i didnt realize how big the mosfet is
85 700
coastered&shaved
uni filters
coil mod
KC's led turn signal boards
clear alternatives led tail light
Wolfies forward controls
vn900 seat
AGM Battery
Iridium plugs
willie and max bags
plexifairing 3
14 inch apes
97 75
parts bike for now
He was the sort of person who stood on mountaintops during thunderstorms in wet copper armour shouting "All the Gods are bastards."
goofin is offline
