Bike was running but won't run now - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-02-2012, 12:33 PM Thread Starter
Hi everybody,
'01' vn 750 Did the PU/coil mod, iridium plugs.
It ran great, then it had clutch issues. In the process of trying to figure out the clutch, might have put in some gas of questionable quality(bad gas).
Up till then it would fire up after only a couple cranks and idle all day. Now it only runs as long as the starter is helping it.
I drained the bad gas out of the tank, drained the carb bowls, blow thru the carb vent and gas comes out the jet holes. It's has good blue spark, fires on both cylinders and the pipes get hot.
But it won't tak off on it's own.
Any suggestions would be appreciated
skrapper is offline
post #2 of 3 (permalink) Old 06-02-2012, 12:47 PM
sounds like a safety switch issue...maybe the side stand switch???
post #3 of 3 (permalink) Old 06-02-2012, 02:13 PM
Make sure that the nuetral switch wire under the engine is connected.
