pickup coil mod..I'M LOST - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 05-31-2012, 10:24 AM Thread Starter
pittdave's Avatar
Ive been looking at all of the posts on the pick up coil mod and I just can't seem to see what it is I am supposed to alter so we can get the smaller gap or, for that matter, which way the gap is. I need some help on this one
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 16 (permalink) Old 05-31-2012, 02:57 PM
do a thread search for pick up coil clearance pics posted by abyssdncr
and when you do the mod make sure you bring the rotor around where you are gaping the pickup at the contact plate otherwise your gap will be way too shallow and you will knock the ends off of the pickup
post #3 of 16 (permalink) Old 05-31-2012, 04:41 PM
post #4 of 16 (permalink) Old 05-31-2012, 05:09 PM Thread Starter
pittdave's Avatar
ive seen that thread.. i dont see what it is i am gapping.. i dont understand what is being done
Pittsburgh Dave
pittdave is offline
post #5 of 16 (permalink) Old 05-31-2012, 05:39 PM
ok...I'll try to explain it quickly for ya....
in the 3rd photo you can see the 2 pickups mounted at 8 o'clock and 10 o'clock. if you turn the engine by hand by using a socket wrench in the middle of the drum, you will see a metallic piece rotate around and come very close to the pickup coils.
If you align the coil with the plate as it rotates...that is the gap you are checking and re-setting.
The drawing shows how each mounting plate is modified to get the pickup closer to the moving "plate" as it passes them. The drawing is showing that you need to elongate the holes in the plate AND file the flat part of the plate (on both ends of each plate) to allow the gap to become smaller.
his drawing is only showing the top part of the plate as modified, but you need to do the same to both holes and ends of each plate.....for both pickups.
I hope this helps.
post #6 of 16 (permalink) Old 05-31-2012, 05:44 PM Thread Starter
pittdave's Avatar
can somebody pm me and give me a phone number to let me know what i am looking at
Pittsburgh Dave
pittdave is offline
post #7 of 16 (permalink) Old 05-31-2012, 06:42 PM
Roach's Avatar
Here is a video of myself gapping the coils
Explanation of the mod earlier in the same video
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #8 of 16 (permalink) Old 05-31-2012, 09:47 PM Thread Starter
pittdave's Avatar
oh... thank you so much... now i get it and i'll tackle that this weekend
Pittsburgh Dave
pittdave is offline
post #9 of 16 (permalink) Old 06-02-2012, 12:13 PM Thread Starter
pittdave's Avatar
OK.. ive had to give up on the mod right now as the screws that hold the pickups will not break loose.. Can any kind of break-free be used there??
Pittsburgh Dave
pittdave is offline
post #10 of 16 (permalink) Old 06-02-2012, 04:37 PM
JM2001's Avatar
On this page-- Impact driver.
http://www.sears.com/craftsman-impac...p-00947641000P
Link doesn't work. Google Impact driver
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
