HELP! LED hookup under bike - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-23-2012, 10:03 PM Thread Starter
Unhappy HELP! LED hookup under bike
Can someone give me some direction? I want to hook up one red LED lamp under my bike onto the frame, so the ground under my ride glows red after dark. Sounds cool, but where is the safest place to tap power from so that it worx with the ignition switch in the on position? I found there is a hot and a ground behind the right side panel specifically for accessories, but it will not turn off with the ignition switch, I did an experiment on my bench - a hot, a ground, to a 3 pole illuminated rocker switch, to the LED. On the first hookup, the rocker light and the LED both worked, but would not turn off with the switch. I switched the wires around, and got some magic smoke and burned the switch out. Can someone help?
James D. Boatman is offline
post #2 of 8 (permalink) Old 05-23-2012, 10:56 PM
wire it up as if you were installing driving lights as per this thread
post #3 of 8 (permalink) Old 05-24-2012, 09:47 AM Thread Starter
Thanks, I will try your suggestion. Please, no more magic smoke!!!!!
post #4 of 8 (permalink) Old 05-24-2012, 09:57 AM
as with all electrical and electronic components, you must keep the smoke inside them....they will not work if the smoke is let out
What type of rocker switch are you trying to wire up?
I would wire it through a relay as Slim suggested above (with an inline fuse) and then you can use your switch to turn them on and off as long as the ignition is in the "on" position.
post #5 of 8 (permalink) Old 05-24-2012, 11:03 AM
I wired up my kit with a wireless 12v switch so I didn't have to mount any external switches. Pretty easy to do and they are reasonably cheap on the bay. Search 12v wireless switch.... just trying to offer alternet solutions.
post #6 of 8 (permalink) Old 05-24-2012, 11:24 AM
Originally Posted by M_Angell View Post
I wired up my kit with a 12 volt wireless switch.....
Guess it's just lack of sleep.... But I found that funny.
post #7 of 8 (permalink) Old 05-24-2012, 12:51 PM
Yeah guess I didn't think of that. I could have said hooked mine up... antihistamines make me fuzzy headed.
post #8 of 8 (permalink) Old 05-24-2012, 01:41 PM
One can not be truly wired, until they are wireless...
dariv is offline
