so the bike runs fine but............ - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 05-19-2012, 04:27 PM Thread Starter
when i take her out for about an hour and get her all lathered up and well warmed then i cut her off and i get no love when it comes to starting again it is my belief that the r/r is getting too hot and not allowing the stator to charge the battery i just pulled it from the original location under the battery box and relocated it to rear of the side cover
I checked my pig tail to the r/r and the plastic part around two of the wires looks melted and burnt no i lie just took a second glance i have a partially torched section on all three yellow wires
any and all suggestions or comments are appreciated
thanks in advance
post #2 of 13 (permalink) Old 05-19-2012, 04:54 PM
If you have 12v+ on the battery still, then you're describing the hot-start issue. There is a pickup coil gap mod that fixes that.
If you aren't seeing 14v charging @ 4k rpm you should test your stator, and your R/R via slims flow chart.
post #3 of 13 (permalink) Old 05-19-2012, 10:18 PM Thread Starter
ok so i suck at flow charts
i went ahead and did the pickup coil mod and she does start easier
the stator is kicking 14 volts or better to the battery at 4k when the bike is cool however once she warms up it barely kicks off 12.5 and this is after the relocating of the r/r
my best guess is that the r/r is bad
oh and i took off my baffles because the left one was broke when that guy backed into the bike and i have my air fuel mix at 3 1/2 turns and she still seams to be a little rich
post #4 of 13 (permalink) Old 05-19-2012, 10:30 PM
You'll want to test the R/R and stator hot. The flow charts are basic resistance tests. Set your MM to the same icon as the test says, and you should be good. :P
btw, turning the fuel screw out makes it richer, and in makes idle leaner.
post #5 of 13 (permalink) Old 05-20-2012, 02:05 AM Thread Starter
ok so after a five mile ride i checked and i have 14 volts at 4k rpms.
the temp was at half way and both heads were at one one th... ouch dont touch that so i think that counts as warmed up.
could the r/r cause an intermittent charging issue?
post #6 of 13 (permalink) Old 05-20-2012, 07:30 AM
If you have a charge of 14v then it should be ok, however you must clean and di-electric grease all connections, if it is getting hot at the connections they need to be cleaned and greased.
Swagman is offline
post #7 of 13 (permalink) Old 05-20-2012, 11:23 AM
your charging system sounds fine... however it sounds like your main grounds are loose or corroded. or your battery is headed south
post #8 of 13 (permalink) Old 05-20-2012, 02:39 PM Thread Starter
brand new super start battery came dry charged
instructions said pour in the acid and let stand for 1 hr
then trickle charge for 14 hrs
and let stand another 1 to 2 hrs before putting in service
only thing i did differently is it was 1 am when the 14 hr charge was thru so i unhooked it and waited till morning to put it in
post #9 of 13 (permalink) Old 05-20-2012, 03:05 PM
That is how I do my batteries too. I usually wait longer than the 1-2 hours they suggest prior to putting it in service.
post #10 of 13 (permalink) Old 05-20-2012, 09:38 PM Thread Starter
so the connector on my r/r just didn't look so swell so i cut one wire at a time and put my own ends on it and placed them back on there respective blades in the r/r and guess what happened?
that's right no more dead battery!!!!!
also like i had mentioned before i took off the baffles because one was broken anyways and then she started missing on the back head.
did the grambo trick just to do it and for ****s and giggles i went ahead and cleaned my coolant bottle while it was off.
grambo took the little tap out of the back head but did nothing for the miss.
so i started adjusting the air fuel mix on the carbs.
starting at 2 and 1/2 and taking a short ride about two miles engine was already warm.
still missing tried three turns same thing so i went on with this half a turn at a time same trip each time and finally at 4 1/2 turns out she is idling smooth and not missing.
now here is the question would the lack of baffles cause me to have these problems and have to go that far out on the mix screws?
