fancy lighting? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 05-15-2012, 05:03 PM Thread Starter
fancy lighting?
I was cruisin down the road the other night and I saw a bike that was lit up like a Christmas tree but what stood out most was the plug wires were strobing!
I thought that was cool as hell and I wondered it must be built into the plug wires but are they as good of a conductor for the spark and if so what is the name of them and where can I get me some?
post #2 of 16 (permalink) Old 05-15-2012, 05:13 PM
Deviate's Avatar
Was it something like this?
Deviate is offline
post #3 of 16 (permalink) Old 05-15-2012, 05:31 PM
sparkingdogg's Avatar
http://www.jpcycles.com/product/3800...FTSytgodSBo_lw
2003 VN1500 Nomad FI Bagger
2004 KLX400SR Dual Sport light adv bike
1969 CB750 K0 sand cast #1767
couple of nice GL650 Silver Wing Interstates, one with hack
2 and 4 stroke dirt bikes
other vintage stuff back in the corner
sparkingdogg is offline
post #4 of 16 (permalink) Old 05-15-2012, 09:37 PM
If only it had 6th gear..
DavesVulster's Avatar
They look cool but anything in addition to the spark plug could drop the charge slightly and one thing about these vulcans is they need a good solid spark to start properly and run consistently. That's why among the most common issues discussed are the electrical and ignition systems. Using lighted wires [/B]may[/B]diminish the spark. I don't know if I'd chance it on a VN, but you might find that it's fine. Just something to be aware of.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #5 of 16 (permalink) Old 05-16-2012, 10:57 AM
The Custom Dynamics ones are cool, but at 100 bucks a set....yikes!!
not to mention there are 4 plugs on the VN750....ouch!
JP Cycles claims that on theirs : "Will not affect plug performance in any way" and are about 9 bucks a piece.
I don't see how they can claim that...they must degrade the pulse signal at least a little.....but, for that price, it might be worth trying.
post #6 of 16 (permalink) Old 05-16-2012, 09:51 PM
Yeah it is a good price, and having that flicker on both sides of the bike Would look cool. You'd be among the few who can do that with a v-twin. If you go for it I think you really ought to do the pick up coil mod if you haven't already.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #7 of 16 (permalink) Old 05-17-2012, 12:58 AM
somewhere in my "final scene of mad max movie" mess that i call a workshop is a strobe light i took off my zx1100 ninja, i think it must be neon, it's bright as hell even at daytime. the transformer/controller is about 2" x 2" x 1" and it has two strobes about 1/2" diameter and 2-3" long that mount with adhesive tape. it flashes like once a second. at night it's really bright. first time i saw it from the corner of my eye, i thought my bike was on fire! it was daytime and i was like "wtf is that???" haha. they were mounted near the muflfler tips. i am sure you could google it and find something similar, probably cheap. and it won't suck a milliamp from your coils. one could be mounted on each side near the bottom of the tank or whatever.
i kinda forgot i had it, might have to mount it now!
post #8 of 16 (permalink) Old 05-17-2012, 01:14 AM
kuryakyn made ones might be better quality, 2 or 4 could be used.
http://www.motorcycle-superstore.com...WT.MC_ID=10010
i would be hesitant to cut the plug wires and add them though, could be a weak link in the chain. i admit it looks really kool at night, but not sure if price and reliability warrants it.
plus i do nearly no night riding!
if they actually use neon gas, and shunt most of the current around the neon, i don't think it would affect performance, we are talking about 20-40,000 volts on the secondary side of the coil. but there are no specs, so no way of telling.
post #9 of 16 (permalink) Old 05-20-2012, 01:15 AM Thread Starter
i found a cheap way to get the strobing effect i mounted two 12 inch led bars under the tank ran the power to a 10 amp fuse and ground to the green wire on the coil the lights get a pulsating ground from the pick ups without reducing power to the plugs creates a nice bright strobe but at high rpms they just stay on because the ground is pulsing so fast
i did mine with red leds so it looks like the engine is bleeding at night
post #10 of 16 (permalink) Old 05-20-2012, 08:40 AM
Deviate's Avatar
Do they stay on all the time or do you have them wired to a switch? With it being red (or if it were blue as well) I think it would be illegal to run with them turned on here. The only red lights allowed on non-emergency/police vehicles are rear facing and no blue is allowed at all.
Deviate is offline
