Turn Signals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-15-2012, 01:06 PM Thread Starter
Model A Guy
Jeff Barnes's Avatar
Turn Signals
Another way to redo your signals if the rubber is rotten and you do not need to relocate them. The signal shave on our forum would not work due to the condition of the rubber stems, however the mounting ends were fine. you can see where I've cut them off. I had to enlarge the hole through them with a drill bit and the resulting tight fit of the replacement signals mounting stems didn't even require a nut to tighten, so the stem doesn't even have to go all the way through. These were generic signals off E-Bay. I did have to change the wire end plugs on the new ones as they did not fit the stock wireing. Swapped them out from the stock signals. Hope this might help someone with the " Ole signal sag!" or even falling off! Any questions on my fix give me a shout.
ID:	4522   Click image for larger version
ID:	4526   Click image for larger version
ID:	4527   Click image for larger version
ID:	4528   Click image for larger version
Jeff Barnes is offline
post #2 of 6 (permalink) Old 05-15-2012, 01:13 PM
nice job!
That looks like a clean install.
post #3 of 6 (permalink) Old 05-15-2012, 02:07 PM
Looks nice
Swagman is offline
post #4 of 6 (permalink) Old 05-17-2012, 10:29 PM
n00b
'85vulcan700's Avatar
awesome look, this definitely helps me look at some more options for my rebuild
'85vulcan700 is offline
post #5 of 6 (permalink) Old 05-18-2012, 02:39 AM
sparkingdogg's Avatar
man thanks for sharing! i have a whole box of broken stems! i was gonna use some stainless washers and a rubber sleeve in the odd shaped hole, now i am gonna do the "jb mod" as it looks great!
2003 VN1500 Nomad FI Bagger
2004 KLX400SR Dual Sport light adv bike
1969 CB750 K0 sand cast #1767
couple of nice GL650 Silver Wing Interstates, one with hack
2 and 4 stroke dirt bikes
other vintage stuff back in the corner
sparkingdogg is offline
post #6 of 6 (permalink) Old 05-18-2012, 06:37 AM
JM2001's Avatar
Looks great
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
