another voltmeter question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-10-2012, 12:12 AM Thread Starter
pittdave's Avatar
I installed the Kuryakyn voltmeter/battery meter today and have a question. Going by the directions, the green lights indicate 12.5-14.5 volts. Upon starting the bike, I am not in the green but I'm there within 30 seconds at idle and it charges up as I rev the throttle.
Should I be in green from the moment I turn the key on, or am I OK as is.
I already have a MF battery, but it was in place from the PO. Not sure if I need to get a new one or not
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 3 (permalink) Old 05-10-2012, 12:35 AM
'03 VN750 "Rosie"
bstew7890's Avatar
I'm not counting on mine for pinpoint accuracy as it's wired into the headlight bucket. When I start it cold with the choke it is green, warming up at about 1,500 rpms. At regular idle it is yellow and when I'm moving it stays green. If I'm ever riding and the green flickers or goes yellow, then I'll know there's a problem. That's all I really need it for. If I need a precise voltage I'll get the meter out of my tool box and put it directly on the battery.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #3 of 3 (permalink) Old 05-10-2012, 12:54 AM Thread Starter
pittdave's Avatar
sounds about like mine, so i guess i'm in good shape
Pittsburgh Dave
pittdave is offline
